Questions: Bagger Toe/Heel Shifter Arm Removal
Old Mar 21, 2012 | 05:14 PM
103 sedona orange's Avatar
103 sedona orange
I took mine off all my Touring bikes. I wear 14 EEE boots & need all the room I can get.
Old Mar 21, 2012 | 05:23 PM
kredin's Avatar
kredin
I never used one until I picked up my RK a couple of years ago. I tried it... I liked it... I always use it.
Old Mar 21, 2012 | 05:25 PM
shakrr's Avatar
shakrr
I bought the extended shifter for the heel and clocked both down dont have to lift foot very much
Old Mar 21, 2012 | 05:28 PM
wilbur24efd's Avatar
wilbur24efd
Stage II
Default Heal Shift All the Way
I use the heal shifter regularly; it is a rapid method of shifting and once you get the hang of it, you'll never go back. The problem is, HD doesn't set these at the proper height when you purchase the bike. If you find you have to lift you foot off the board to get to the heal shifter, it's set too high. Lower it so your foot can maintain contact with the board and your heal can rest on the heal shift comfortably. It should be set so that there is just enough room to click a gear. Once set right, you can bang through gears faster and smoother with the heal shift. There is no problem with removing it; looks better with it (just my opinion). Good luck
Old Mar 21, 2012 | 05:33 PM
Copyless's Avatar
Copyless
I always use my heel shifter, and I changed out the OEM one with one from Wicked Image, the tribal flames/skull one. It extends the OEM length 1 inch in both directions and really clears out the whole foot board.
Old Mar 21, 2012 | 06:25 PM
scottburns8ball's Avatar
scottburns8ball
yanked mine off and took the floorboards off too. Put forward controls on. Love 'em. Never go back to floorboard or heel shifters.
Old Mar 21, 2012 | 06:28 PM
KSGLIDEGUY's Avatar
KSGLIDEGUY
I removed mine so I could slide my foot as far back on the floorboard as I want to. I grew up on dirt bikes so I could never get used to a heel shifter.
Old Mar 21, 2012 | 06:33 PM
smithbrl's Avatar
smithbrl
When my bike was new, I really liked the heel shifter. The only way I could get it into neutral was go to 1st then tap down on the heel shifter. After the clutch/transmission loosened up I can use the toe shifter to find neutral so I removed the heel shifter and installed the spacer to move the toe shifter out a little.
Old Mar 21, 2012 | 07:15 PM
GPHDXLC's Avatar
GPHDXLC
Same here, I love the extra room for my left foot.
Old Mar 21, 2012 | 07:26 PM
mcryder's Avatar
mcryder
I just took mine off and neutral is a pain to find with the bike sitting still. I hope it gets better as the tranny wears a little. I really like having the extra foot room.
