Pyo monkey bar wiring — cut or remove deutsch
Old Mar 22, 2012 | 05:24 PM
timvan's Avatar
timvan
Default Pyo monkey bar wiring — cut or remove deutsch
Ok so ive been screwing with wiring up 12" monkey bars. Ive spent about an hour usimg chain, weed eater line and string.. This is miserable! Ive wired up many bars but this takes the cake.
Are.you guys cutting the deutch connectors or disassemble them?
Old Mar 22, 2012 | 05:30 PM
uscanuck's Avatar
uscanuck
Just take the wires out of the connectors. Just need some needle nose pliers and a paper clip to remove.
Check out Wild 1 website for details on how to remove wires.
Go to http://www.wild1inc.com/ select Touring on the left side and when that loads, under the picture of the TBW connector it says "Wiring Tips."
Old Mar 22, 2012 | 05:40 PM
BlueShift's Avatar
BlueShift
I checked your bars out online, turns look a bit tight.
When I did my apes I prestrung the bars with nylon mason line attaching a fishing split shot that fit through the holes in the bars.
Start at the top shaking the bars as you go, split shot should fall right out of the center slot.
Tape each line of to the bars.
disassemble the deutsch connectors , make a diagram of the wire locations if you don't have the service manual.
You can make a small hook out of wire to grab the mason line .
Good luck.
Old Mar 22, 2012 | 08:40 PM
timvan's Avatar
timvan
Guess my question is leaning more towards will the pins make the turn? I have the connectors apart, ive broken everything ive used to pull the wires.
Old Mar 22, 2012 | 08:47 PM
WI Bob's Avatar
WI Bob
Lube it
http://www.idealindustries.com/products/wire_installation/lubricants/clearglide.jsp
Old Mar 22, 2012 | 09:40 PM
Urb's Avatar
Urb
Default weedeater line
I used weedeater string, no lube. Worked great. Tried fishing line, cable, lube, nothing else worked, took two days of frustration, lots of Miller Lite, but finally the weedeater line worked great. Have fun
DJY
Jul 9, 2013 06:04 AM
3skulls
Jan 25, 2011 10:29 AM
ICIBUY
Jan 30, 2010 04:35 PM
drogers
Jun 1, 2008 06:26 AM
0ut1aw
Mar 14, 2008 11:32 PM
