Tour Pak Light Conversion Kit
Old Feb 10, 2013 | 10:21 AM
2013UltraLimitedKB's Avatar
2013UltraLimitedKB
Stage III
How did you hook up the side lights on the tour pak? the original wiring was removed with the lights and there is no mention of how to connect them in the HD kit?
Old Feb 10, 2013 | 10:44 AM
Stang951's Avatar
Stang951
Originally Posted by Hayhoss
If I were to do it over again, I would purchase the Custom Dynamics tour pak conversion kit. Plug-n-play plus it also does the run, turn brake to the tour pak side leds. Craig
++1 Here. That is how I got the lights on my tour pak to work with my Street Glide. All I did was run an extra wire for a ground. Made wiring the lights a breeze. And like mentioned you get all functions including hazards which you do not get with the HD kit, AND there is no extra relays/boxes to put anywhere.
I do believe however that you HAVE to upgrade to LED lighting (like thats a big deal...win win because you have better lighting at that point).
Old Apr 17, 2013 | 10:07 PM
Ultra Pearl's Avatar
Ultra Pearl
On the ultra there are running lights and brake lights stock on the tour pak. So does this kit only add turn signals to the tour pak?
I'm confused with this part #6940004A because the description says it adds an auxiliary brake light and turn signal function to the OE tour pak.
But if you have running and brake lights stock, do you only use the signal part of this harness?
Old Apr 18, 2013 | 12:50 AM
Harleypingman's Avatar
Harleypingman
Install per the directions and the corner lights become turn signals in addition to their normal run/brake functions.
If you use the search function you will find a thread I did with video on this kit.
Carl
Old Apr 18, 2013 | 04:22 AM
ENG5INE's Avatar
ENG5INE
Originally Posted by Ultra Pearl
Did anyone else have this liner problem, it would seem if the liner sits up higher it would interfere with the lid closing.
Whats the point in buying something to solve one problem only to create another..
I didnt have the problem either i got my plug and play kit thru custom dynamics and really like it knock on wood no issues at all
Old Apr 18, 2013 | 04:33 AM
ENG5INE's Avatar
ENG5INE
Ultra with the custom dynamics kit my tour pack side markes light up as a brake light and as a turn siginal the rear lights are also turn siginals and brake lights
Old Apr 18, 2013 | 07:01 AM
Harleypingman
Just noticed that UltraPearl started this thread 13 months ago and resurrected it.
He gets my "Careful Shopper" award.
Carl
Gatlin
Mar 25, 2019 07:08 AM
PSRumors
Aug 28, 2016 03:57 PM
dh2683
2014-2024 Touring Models
Sep 2, 2014 09:35 AM
riconot
Feb 23, 2008 09:29 AM
oley55
Feb 24, 2007 08:33 PM
