passing lamps on SG question
Old Dec 27, 2006 | 12:31 PM
coolnite's Avatar
coolnite
Default RE: passing lamps on SG question
ORIGINAL: mtdrop
ORIGINAL: 06BlackFLHXI
Hi
I just finished installing the passing lamp kit for the Street Glide. Very happy with the look, would have been an easier job if not for the damn confusing HD instructions.
My question is this, the passing lamps work fine with headlight on low beam but when I activate the high beam they shut off, Is this normal? As added info I have the HD garage door opener swhich is wired through the high beam, not sure If it is pertinent.
Thanks in advance
So how bad was the install? Thinking about doing this too and was wanting to know should I take to the dealer or try to install myself. Also any pics of the finished product?
Back to your question.
It's nothard to install passing lamps on a Street Glide. A HD Service Manual for your specific bike will be very helpful.
Here is a summary of the process of installing the passing lamps part #69818-06.
[blockquote]
1. Remove the battery cables, negative first. I just made sure the switch was off.
2. Remove the windshield.
[blockquote]
a. There are 7 screws that secure the outer fairing, 3 on the windshield and 4 on the fairing.
b. Loosen the 2 screws (torx) near the top of fairing.
c. Remove the 3 windshield screws.
d. Gently remove the windshield.[/blockquote]
3. Remove the fairing.
[blockquote]
a. No need to remove the headlight from the fairing
b. Remove the 4 screws (torx), 2 on each side, on the fairing. The outer fairing will fall off.
c. Remove the plug from the back of headlight[/blockquote]
4. Remove old turn signals.
[blockquote]
a. Trace the wires from each turn signal back its connector in the fairing. One connector on each side.
b. Unplug the turn signals
c. Remove the old turn signal assemblies from the front forks.[/blockquote]
5. Disassemble old turn signals.
[blockquote]
a. Note (write down) the location of the turn signal wires in each connector.
b. Using a straight pin release the pin lock and remove the 2 wires from each connector.
c. If you're doing it correctly, the wire comes right out. Don't force it.
d. Remove the turn signal from the old bracket.[/blockquote]
6. Assemble new passing lamp / turn signal assembly.
[blockquote]
a. Follow the directions in the kit.
b. Pay attention to the wire routing within the assembly.
c. You do not have to remove the pins from the turn signal wires.
d. Install a pin (included in the kit) on the end of each passing lamp wire (grey).
e. Put the turn signal wires (2) back into each connector.
f. Put the grey passing light wire into each connector. Look for the grey wire in the fairing connector for the correct location.[/blockquote]
7. Remove the fairing cap and the ignition switch.
[blockquote]
a. Turn the forks all the way to the left.
b. Look under the fairing cap (that's the plastic piece under the ignition switch that has places for 4 switches) and unplug the wiring harness.
c. Insert the key. Turn the ignition to unlock.Turn the ignition to fork lock.
d. Depress the release buttonon the bottom left of the ignition, push the key down and turn the key 60 degrees counter-clockwise.
e. Lift and remove the ignition ****. A spring will fall out of the ****.
f. Remove the nut (7/8") and spacer. You may have to turn the forks to the right to get at it.
g. Remove 2 screws (torx) from the fairing cap. 1 on each side.
h. Remove the fairing cap.[/blockquote]
8. Install the passing lamp switch.
[blockquote]
b. Remove the two screws that hold housing for the 2 left switches.
c. Install the passing lamp switch in the housing (left-most switch).
d. Re-install the switch housing into the fairing cap.
e. Install the wires from the passing lamp switch into the main plug.
f. Secure wiring neatly with wire ties
Old Dec 27, 2006 | 12:42 PM
mtdrop's Avatar
mtdrop
Thanks Coolnite for that detailed list on the passing lamps. I think I'll just pay dealer to do.
Old Dec 27, 2006 | 02:39 PM
jmorton10's Avatar
jmorton10
It's a pretty simple install, I think it took me about an hour.
PASSING LAMPS ON MY RK CUSTOM
~John
Old Dec 27, 2006 | 08:58 PM
StreetGlide2006's Avatar
StreetGlide2006
I had mine installed before I picked up the bike. I got 20% off lights & install that way. I recently added the visor rings to mine & love the way they look.
RIde Safe,
Mike
Old Dec 27, 2006 | 09:13 PM
Towpro's Avatar
Towpro
ORIGINAL: StreetGlide2006
RIde Safe,
Mike
Looks sharp StreetGlide2006, good lookin' scoot man.
Old Dec 27, 2006 | 09:25 PM
quickone87's Avatar
quickone87
thats funny my lightbar looks totally differant then everyone else's mine looks like a original electraglide bar !!! oh well everything bolted up normal to my 07 sg i guess !!!!
Old Dec 27, 2006 | 09:30 PM
BadX's Avatar
BadX
ORIGINAL: mtdrop
Hi
My question is this, the passing lamps work fine with headlight on low beam but when I activate the high beam they shut off, Is this normal? As added info I have the HD garage door opener wich is wired through the high beam, not sure If it is pertinant.
Thanks in advance
Dont have pics but It looks very good, there are a lot of guys here on the forum with them on to form your own opinion. As far as instructions, well let me say that you have to bevery patient and calm, the HD instructions are simply terrible. you got to take your time and think It through, a manual is a must. My only real problem was with the ignition switch. When Icame to put it back on i went too quickly thinking that I remembered, but instead I put It on wrong, had thebike all locked up, anyways after a few deep breath and a bit of common sensei got It right. I would say that the dealer would charge you 2.5 to 3.0 hours of labour for install, very glad I did it myself.
Im glad I wasnt the only one that locked their bike up...LOL My install wasnt too bad, the instructions do suck though. Im glad you got it worked out dude, nothing like self satisfaction and saving money by doing it yourself.
Old Dec 27, 2006 | 09:52 PM
shortleg's Avatar
shortleg
Ya,I just got done doing mine.I found that the instructions suck.
But like everyone has said just take your time.
I found that the hardest things were the routeing of wires and the ignition switch.
But man they do look great..
Now Friday with the help of good friends we are going to do the chrome slider kit.
Pray for me!
Shortleg[Dave]
Old Dec 28, 2006 | 03:27 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
I'd be interested to hear how the sliders go.[sm=alcoholic.gif]
Old Dec 28, 2006 | 05:05 PM
BadAzz Electraglide's Avatar
BadAzz Electraglide
Sliders are easy onthe SG specially if your not lowering the front forks at the same time. Sliders can be changed without removing forks from triple tree.
