do i really need an EFI
Old Mar 26, 2012 | 08:04 PM
ekleharley's Avatar
ekleharley
2nd Gear
Default do i really need an EFI
Decided on Rineharts but haven't decided on 3.5 or 4 so I called Rinehart to get some additional information.. I was told if I buy Rinehart slip on mufflers, I need an EFI and I should get the ThnderMax and it cost 1000.00. If this is the case, I will pass on the Rinehart's. What say you????
Old Mar 26, 2012 | 08:07 PM
Keithhu's Avatar
Keithhu
Bunk. Just buy a set of VIEDs for $100, plug them in and ride happy.
http://sales.nightrider.com/Touring_c_16.html
Old Mar 26, 2012 | 09:10 PM
Lowcountry Joe's Avatar
Lowcountry Joe
That advice does not make any sense at all. If you actually called Rinehart, they are in the business of selling mufflers, not EFI modules. Hmmmmm...
Old Mar 26, 2012 | 09:16 PM
ekleharley's Avatar
ekleharley
2nd Gear
said i should get a thunder max and when he said 1000.00, i said forget it..... this is the first time someone told me I needed this
Old Mar 26, 2012 | 09:56 PM
mkguitar's Avatar
mkguitar
If you are ONLY changing mufflers and retaining the stock header AND stock air cleaner- you will likely need no tuning compensation.
IF you are changing mufflers AND header pipes you may need tuning compensation.
IF you are changing headers, mufflers and air cleaner ( to a high flow) you almost certainly WILL need tuning compensation.
My choice for about $125 are nightrider.com XIEDS ( pick the ones for your year and model).
IF you think you will ever also be changing cams or doing headwork- then you should have a more complex device.
I do not use any of the tuners, but the Thundermax gets fewer questions and/or complaints than other devices here at the forums.
Mike
Old Mar 26, 2012 | 10:04 PM
scotracy's Avatar
scotracy
Mike[/quote]
Not necessarily true, although a good idea. According to the experts at American Iron Mag. they have done numerous exhaust and A/C changes without a tuner with no ill effects. Your ECM will adjust, as long as you do one, then ride for several on and off cycles to set ECM then do the other. I did a tuner, but I plan on doing future upgrades.
Old Mar 26, 2012 | 10:09 PM
HeHateMe's Avatar
HeHateMe
A thundermax would change your life! It's a must have sooner or later. Stick with rinehart, do it right, do it once. Don't let that turn you off.
Old Mar 27, 2012 | 12:18 AM
RDKNG2011's Avatar
RDKNG2011
i bought rineharts.. you will need a tune if you do anything other then slip ons i did the classic duals and had jamie program me a powervision.. of course i also did cams but regardless.. i got my pv for half that and i'm thrilled
Old Mar 27, 2012 | 02:25 AM
Patriot60's Avatar
Patriot60
Hmmmm, funny, I already new this info but stopped at the Rinehart shop at Sturgis last year just to see if they were just trying to sell me something. They told me if I did anything more than slip ons, I would have to do a tuner. They recomended the Thundermax, which by the way is a great piece of electronics. They never tried to sell me anything I didn't need.
Old Mar 27, 2012 | 05:32 AM
grbrown's Avatar
grbrown
If your bike is currently stock, your bike meets all the noise and emissions regulations, which means it probably runs hot, as the air/fuel ratios are lean. Changing your mufflers will alter the current settings and may make it run yet more lean. By doing nothing else, you are relying on the stock EFI to compensate, something it is not designed to do! I personally wouldn't alter an EFI bike without compensating properly for the changes.
James11
Exhaust System Topics
May 8, 2015 04:34 AM
1Digger
Jul 24, 2013 08:41 PM
cubcake1
Jun 20, 2007 11:23 PM
jeff986301
Jun 17, 2007 09:41 PM
winndl
Feb 24, 2007 06:43 PM
