amp questions
Old Mar 26, 2012 | 09:08 PM
06-flhtpi's Avatar
06-flhtpi
6th Gear
Cool amp questions
I have an 06 flhtpi with a Sony marine radio and 5 1/4 hertz speakers in the fairing. I'm installing kuryakyn speaker lids. They recommend the kicker 871 amp, but not for $500. I was thinking about the Rockford fosgate pbr 300x4. The thing I'm worried about is the hertz speakers are 3ohm and the amp is 4ohm. I don't know much about amps will this combo work. I also am having trouble finding info on the kicker speakers in the lids but I think they are 4ohm. Thanks
Old Mar 26, 2012 | 09:42 PM
the bad bagger's Avatar
the bad bagger
I run the HERTZ 6.5 High Energy which are also 3ohm with the Rockford Fosgate as well. The speaker wire adds resistance which will make the speakers 4ohm. The speakers actually read about 3.6 to 3.7 ohm without speaker wire. You will be fine with that setup.
Old Mar 26, 2012 | 10:57 PM
06-flhtpi's Avatar
06-flhtpi
6th Gear
Cool thanks for the info. Was that amp easy to install?
Old Mar 26, 2012 | 11:08 PM
texasjon's Avatar
texasjon
6th Gear
how much better are the hertz speakers over stock? I got a ultra ...supposed to have a amp ....I cant tell a damn bit of difference with that switch tho
Old Mar 26, 2012 | 11:33 PM
06-flhtpi's Avatar
06-flhtpi
6th Gear
I have a police bike so it didn't have a stereo. I added a biktronics kit, radio and speakers so I can't compare. The hertz speakers were an upgrade from the hog tunes speakers. It may just be under powered.
Old Mar 28, 2012 | 08:51 PM
the bad bagger
The amp is easy to install use high level input. Cut off the RCA plugs run your speaker wires from the head unit to the amp. the hardest part will be taking apart the fairing and gas tank removal. A couple of hours at the most.
Old Mar 28, 2012 | 09:01 PM
the bad bagger
The HERTZ speakers make a world of difference if running a 4ohm
amp. The stock speakers are just stock speakers. Good for selling on the showroom floor not good on the road. The Hertz speakers like to be driven so I put 100 watts RMS through each speaker. I do not know how they sound with a stock head unit. The stock radio is 2ohm.
I have an aftermarket Sony.
shaneballance
Audio Systems
15
Aug 13, 2018 03:51 PM
2007z71
Audio Systems
Mar 29, 2015 10:53 AM
CHIPMOVER
Audio Systems
Jan 28, 2015 11:18 AM
Jagpanzer
Audio Systems
Oct 11, 2014 08:30 AM
Mirnldi@gmail.com
Audio Systems
19
Jul 17, 2014 08:03 PM
