Got A Cleaning Question?
Old Mar 27, 2012 | 11:07 PM
  #31
BBStacker's Avatar
BBStacker
Good 'Ol Pig Spit.
Old Mar 27, 2012 | 11:45 PM
  #32
Joboo1966's Avatar
Joboo1966
Originally Posted by BigJimmy
S-100 Engine Brightener is made just for that!
Go to Harley and spend the 13 bucks on the engine bright for black wrinkle, not only does it work on making the engines look like new (literally) but it works on any other black components including floor board bottoms if you have the stock plastic black ones, it also shines the black part of the inner primary and around the transmission etc. Pig spit used to work but now it's owned and distributed by six different labels under the same brand name each with an obvious formulary difference from the other that make results unpredictable and disappointing cosmetically and financially if you get the wrong can.
I'm not one to boast the expensive HD brands , I personally feel the MOCO is way overpriced, but one spray can will last vtgree seasons and really does the job, giving more bang for the buck. I use it and my engine looks like new and it does withstand the elements , I've washed my Glide six times since the last application of his stuff and it still looks like I I'd the day I applied. Biggest tip/trick.........make sure the surface you are spraying is lean, dry and free of other waxes, solvents, oils and armor all type substances hat interfere with he adhesion properties of he spray. You will not be disappointed.
Old Mar 27, 2012 | 11:48 PM
  #33
Joboo1966's Avatar
Joboo1966
If its too clean you ain't riding it snuff !
Old Mar 28, 2012 | 12:35 AM
  #34
gunnyBob's Avatar
gunnyBob
Silicone spray or Balistol. These two are cheap and work perfectly.
Old Mar 28, 2012 | 04:18 AM
  #35
paulgaines319's Avatar
paulgaines319
2nd on the S100 engine brightener. Great stuff, really easy to use.looks great also.
Old Mar 28, 2012 | 04:21 AM
  #36
dickey's Avatar
dickey
I wouldn't use Armor all--it creates a dependancy on whatever you use it on.
Naaawwwww.....whatever gave you THAT idea??
Old Mar 28, 2012 | 06:15 AM
  #37
wisemx's Avatar
wisemx
Pig Spit is still sold on Amazon.
It works wonders on Black.
Old Mar 28, 2012 | 08:25 PM
  #38
Stickman81's Avatar
Stickman81
Originally Posted by FAUVDOG
Accidently hit my motor with wax drives me nuts how do you get wax off the black finish of the motor
A few things you can try -
* Isopropyl alcohol on a cloth. Use a brush if needed.
* All Purpose Cleaner and a brush.
* Mr. Clean Majic Eraser.
Try in an inconspicious spot first, for a short amount of time, but I have read about these.
Old Apr 2, 2012 | 10:56 PM
  #39
aces25's Avatar
aces25
If pig spit is just silicone spray, will any silicone spray do?
Old Apr 2, 2012 | 11:17 PM
  #40
rbferg's Avatar
rbferg
Another vote for S-100 Engine Brightener. Works great!
