Seat cuts into leg
Old Mar 31, 2012 | 08:17 PM
Airborne350G's Avatar
Airborne350G
Default Seat cuts into leg
Well my stock seat cuts into the back of my thigh. I feel an edge and it starts to bug me after an hour in the seat. So what seat would have a more narrow nose that does not move me forward or up? I have a 32" inseam. Thanks
Old Mar 31, 2012 | 09:35 PM
mkguitar's Avatar
mkguitar
year/model?
some details would allow other riders to offer some help.
Mike
Old Mar 31, 2012 | 09:50 PM
baust55's Avatar
baust55
YOU MIGHT CONSIDER MeanCity Cycle
call Allen and see if you can modify your seat for you . WAY WAY cheaper than buying a new seat .
They lowered and narrowed my seat and added memory foam for comfort. total cost just under $150 including shipping both ways.
Old Mar 31, 2012 | 10:00 PM
Fire-Medic's Avatar
Fire-Medic
I have an '11 Limited, 32" inseam, sent my seat to Allen @ MCC, he moved me down 1.5" to have the more "in the bike feel" and back 2" because I have long gorilla arms and I also didn't want to be so much on top of the tank, and he narrowed the front of the seat for me, and put the memory foam for me and the wife. The seat is "perfect" and cost a lot less than an aftermarket seat. Was an easy process, and since all work is done by appointment you don't have as much down time.
I cannot say enough good things about Allen and MCC!!!
He's a member here on the forum, his SN is "BadX", send him a pm if you have questions.
Old Mar 31, 2012 | 10:11 PM
Airborne350G
Originally Posted by mkguitar
year/model?
my sig pic shows 2012 Ultra Limted. Hmmmmm. I guess some might have signatures turned off.
Old Mar 31, 2012 | 10:12 PM
TNB's Avatar
TNB
You may want to try a local upholstry shop and have them "fit" it to you.
Old Mar 31, 2012 | 10:23 PM
jjnoble's Avatar
jjnoble
I don't think I would go to Mean City again for a more comfortable seat, but for something like reshaping the seat they would be worth checking out. If the only problem you have with your seat is the shape then you should give them a call.
Old Mar 31, 2012 | 11:11 PM
Navyrep1's Avatar
Navyrep1
If you're anywhere near Seattle, Rich's is the best deal around....great custom fit.
Old Apr 1, 2012 | 01:25 AM
mkguitar's Avatar
mkguitar
Yup, no ads no pics no dancing hamsters for many of us who are blocking scripts or 3rd party sites.
Even though my bikes and city "should" show when I am asking questions, I add pertinent info.
...If you are reasonably happy with your seat otherwise, do you wear flat shoes or thick soled boots?
Thick soles might lift your knees and change the angle of your thigh across the seat edge.
or if you have extended the boards out bring them back in.
Other wise it is a new seat or a remodel ( bummer, I have good luck with that stock seat- my inseam is just little longer than yours)
- and your jeans do not have a seam ( like the bottom of the pockets) that could be bothering you in that area?
Mike
Old Apr 1, 2012 | 10:12 AM
dougbk's Avatar
dougbk
I am not sure about the newer style frame on the 12 model but on the 08 and older you can adjust the floorboards up which could give you some relief at no cost.
Jersey Drew
2014-2024 Touring Models
Apr 12, 2017 07:20 PM
FLMARK
Aug 5, 2014 02:49 PM
remike
Nov 12, 2010 10:39 AM
matthewthamm
Oct 5, 2009 05:19 PM
MDodson
May 23, 2007 12:55 AM
