Worn Steering System
Old Apr 1, 2012 | 08:13 PM
IRIDE4me's Avatar
IRIDE4me
2nd Gear
Default Worn Steering System
What are signs/symtoms of a worn steering system regarding a 2002 Electra Glide Classic.
Old Apr 1, 2012 | 11:31 PM
X Iron Butt's Avatar
X Iron Butt
Your bearing races will get grooves in them in the most used areas. Like straight ahead and a little to left and right. If you adjust the bearing snug while pointing straight ahead you will feel the grooves as the bearing rolls out of them with a more severe left and right turn and the steering will bind to some extent.
Old Apr 1, 2012 | 11:33 PM
soft 02's Avatar
soft 02
Get the front off the ground and feel for bearing indexing like stated above. Might just need to have fall away checked tightened up.
Old Apr 2, 2012 | 12:38 AM
Harleypingman's Avatar
Harleypingman
How many miles on the bike?
Carl
Old Apr 8, 2012 | 05:04 PM
IRIDE4me's Avatar
IRIDE4me
2nd Gear
Harleypingman -- I have about 45k on the bike.
Old Apr 8, 2012 | 06:10 PM
hog-doc's Avatar
hog-doc
When was the last the neck bearings were adjusted?
Old Apr 17, 2012 | 04:35 PM
IRIDE4me's Avatar
IRIDE4me
2nd Gear
Thanks all. Its just frustrating with my bike. I just had new tires put on because the bike was grabbing cracks in the road, etc. I asked around and most thought that would do the trick, but it is still grabbing cracks and the steering feels off. Kind of like tracking to the right. Wasn't sure if it was the front springs or what. I'm to the point where I don't know what to do next. I'm not mechanically inclinded, I just ride.
Old Apr 17, 2012 | 04:36 PM
soft 02's Avatar
soft 02
Depends on brand of tire for me. Stock dunlops grabbed bad but the Metz 880 track great. What did you put on it?
Old Apr 17, 2012 | 05:06 PM
txfxstrider's Avatar
txfxstrider
Check the fall away and adjust the neck bearings or have it done.
Old Apr 17, 2012 | 08:11 PM
Punjabi Rider's Avatar
Punjabi Rider
I had that issue with my 07 UC with 65K didn't feel comfortable in corners and uneven road surface after adjusting the goose neck few times I had enough, replaced the bearings and every thing else around it rebuilt the front forks and re balance the front tire and finally I can ride it the way I like to ride (aggressively).
Ron Jewell
Sep 5, 2018 09:55 PM
Sanyasi
May 28, 2014 05:29 PM
anthony_b.
Jun 26, 2013 06:57 AM
cjbmustang
May 28, 2011 06:38 PM
Fossil
EVO
May 20, 2009 04:58 PM
