Ipod Sounds like...
Old Apr 2, 2012 | 07:24 PM
jjpish's Avatar
jjpish
Default Ipod Sounds like...
Yesterday I tried using my Ipod on a ride. I had it plugged into my aux on my stereo and it just sounded terrible. At first it was so distorted and blown out sounding. I adjusted the output volume all it did was lower the volume and made me have to turn the stereo volume up still sounded like crap. I pulled over and plugged in my droid the same way put on Pandora and rode for 5 hours music sounding perfect.
I tried songs that I purchased directly from Itunes as well as uploads from CDs both sounded terrible. I have the Boom Audio speakers and like I said my droid with Pandora sounded awesome as well as any cds. So what is the deal with the Ipod? Has anyone else had this problem?
Old Apr 2, 2012 | 07:47 PM
Shortbus captain's Avatar
Shortbus captain
Stage IV
The best way to get good sound is to plug into the bottom of the iPod where you charge it. The problem it that the kit is expensive. I have correct set up on a off road truck into a amp that has RCA jack inputs but you cannot do that on a stock Harley radio. But the sound is night and day. Thare may be another way but I don't know it
Old Apr 2, 2012 | 07:48 PM
kjkustoms's Avatar
kjkustoms
Did you check the EQ settings on your Ipod? Could be the problem, just a guess.
Old Apr 2, 2012 | 07:53 PM
drew4jan's Avatar
drew4jan
The problem is that you are using the headphone jack which is amplified audio. By using the connector on the base you use line audio and are using the amplifier in your radio just like a stereo in your home. I have the iPod interface and yes it is expensive. I used chrome cash to purchase it and am very happy with it. I grew tired of the bad sound through the aux input.
Old Apr 2, 2012 | 07:56 PM
jjpish's Avatar
jjpish
Thanks that makes sense. I was considering purchasing the interface some time down the line but after yesterday I was thinking that was out.
Old Apr 3, 2012 | 09:42 AM
ChristoHD's Avatar
ChristoHD
I have 3 iPod's (not bragging just sharing something I learned) - I have the 8GB Nano 3rd Generation, The 16GB Nano 5th Generation, and then I JUST broke down and bought the postage stamp 16GB Nano 6th generation.
The 8GB worked just fine using the audio out through the Audio in on the H/K HD radio - you do have to play with the EQ settings to get the optimum sound quality and loudness. I then used the 5th gen the same way UNTIL I broke down last year and bought the HD Accessory iPod integration set up.
Using the HD iPod set up:
The 5th Gen would not work at all - no idea, went through 3 returns of the HD set up while it was still at the dealer. Then we tried the older 3rd gen, and it worked... OK. Still had some weird quirks and poor sound quality compared to what I WAS getting using the audio in/out set up.
Then last week I said let's try something so I ordered the 6th gen postage stamp one and WOW - BIG difference!! Sounds EXCELLENT, loud, clear, and so far so weird wonkiness or use issues like I was having. YMMV
HTH
Old Apr 3, 2012 | 09:52 AM
Guntoter's Avatar
Guntoter
I have a 2nd gen IPod Shuffle that I had Capt. Itch make me up a leather pad with magnetic base to mount on the tank and use a cheap (like 2 bucks cheap) cable to connect the IPod to the aux jack on my Sony Biketronics radio setup. Sounds just as good as CD's or the USB stick. Of course I am not running an amp or big speakers either so maybe that has something to do with it. The Shuffle only has an output jack.
Old Apr 3, 2012 | 10:02 AM
PistonPuller's Avatar
PistonPuller
Personally the other problem is you are using it through the HK radio. I upgraded to the sony radio and it works great
http://www.biketronics.com/products/...%252dS100.html
Old Apr 3, 2012 | 10:11 AM
56tbird's Avatar
56tbird
definitely use the EQ, the first thing to turn off is Bass boost....the speakers and radio can't handle it and is sure to distort things.
Old Apr 3, 2012 | 10:17 AM
Geoff's Avatar
Geoff
I play my iPod through the Aux connector on my Harmon-Kardon stereo and it sounds great. As someone above suggested, check the EQ settings on your iPod (and iTunes) and then do another sync.
Also, check the adapter cable. Make sure the jacks have good connections at both ends. Some of the less expensive adapters have undersized jacks that compromise connections.
