Scared to drill
Old Apr 9, 2012 | 08:31 AM
kredin's Avatar
kredin
I was nervous when I drilled mine for the same purpose. Measured, re-measured and then once more just to be sure. I just followed the instructions and low-and-behold... it worked.
Old Apr 9, 2012 | 08:39 AM
jeffreydsilver's Avatar
jeffreydsilver
Default Use Tape & A Sharp Bit
Like everyone before me stated, use tape on the outside surface BEFORE you start drilling. This will prevent the paint from chipping! As far as drilling from the inside, don't waste your time. It's nothing more than plastic. It should drill clean!
MOST IMPORTANT - MEASURE TWICE - DRILL ONCE!!
Old Apr 9, 2012 | 08:55 AM
NOLAMike's Avatar
NOLAMike
I bought this one (http://www.amazon.com/Tusk-12-Volt-P...3979470&sr=8-2) for $12. I mounted on the saddlebag guard next to the seat and wrapped black electricians tape around the wires. It's pretty inconspicuous there and no holes required.
Old Apr 10, 2012 | 09:25 PM
Ben E's Avatar
Ben E
folks, i appreciate the tips. I am interested in doing what Eric D. did in post 9. LIke the versatility of the Powerlet products. Eric what is that bit called? will post pictures when done. thanks, benny
Old Apr 10, 2012 | 09:55 PM
Just Dave's Avatar
Just Dave
Originally Posted by hog-doc
Haha, Iam geussing youve never used a step bit if you THINK a hole saw is gonna do a cleaner job and a step bit is asking for trouble!
As a matter of fact, I have used step-bits before but I know what I am doing. A step bit in the hands of a novice is asking for trouble whereas a hole saw is idiot proof. It is not a matter of "thinking that a hole saw will do a cleaner job", it is a matter of knowing. I am guessing (spelled correctly) that the OP is a novice since he is scared to drill a hole in the first place. Don't assume what I have and have not done until you get to know me a little better.
Old Apr 10, 2012 | 09:58 PM
Just Dave's Avatar
Just Dave
Originally Posted by Bigdave12768
How do you finish it from the other side???? The drill wont fit in bag
I would get out my right angle drill for that problem.
Old Apr 11, 2012 | 07:08 PM
EricD10563's Avatar
EricD10563
It's a Hole Saw or hole cutter. I also have a Powerlet point mounted to my horn that I use for heated gear.
Old Apr 11, 2012 | 11:12 PM
danmo's Avatar
danmo
I just drilled a hole in my saddle bag for an audio cable and I was worried about cracking and paint chipping. It drilled more easily than I expected. I started with a small bit and worked my way up the size I needed. Just mark where you want it and drill away (slowly).
Old Apr 11, 2012 | 11:13 PM
danmo's Avatar
danmo
P.S., I just used regular drill bits
Old Apr 12, 2012 | 11:24 AM
DavidStiebel's Avatar
DavidStiebel
If you are afraid to drill...
Use a hammer!
richard567
EVO
13
Jan 26, 2015 05:52 PM
frankiefire702
May 3, 2011 06:34 PM
JPL
Mar 30, 2011 09:29 AM
SgtMic
Apr 16, 2010 09:11 PM
Rat bike
Ironhead
Jun 27, 2008 11:02 AM
