Grip Adhesive
Old Apr 10, 2012 | 04:35 PM
Jeffs386's Avatar
Jeffs386
hair spray
Old Apr 10, 2012 | 05:56 PM
BackRoader's Avatar
BackRoader
Ol' lady's hair spray works as good as glue, and easier to remove later.
Old Apr 10, 2012 | 06:14 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Hey thanks for all your help I will checkout all of them for best applications.
Old Apr 10, 2012 | 06:36 PM
floridapoolboy's Avatar
floridapoolboy
How do you get a grip that's glued on to come off? I used the black widow glue that comes with the Iso grips, now I want to switch out my handlebars. That grip is on there, not sure how I'm gonna get it free.
Old Apr 10, 2012 | 06:56 PM
TWIN CAM 96
WD40 / acetone
Old Apr 10, 2012 | 07:05 PM
Deucedog's Avatar
Deucedog
I've used air pressure in the past. A little heat from a hair dryer, then insert an air line under the grip. You don't need 110 psi here, unless you want to create either a bomb or a missile. Also, make sure the grip isn't aimed at something breakable. lol
Old Apr 10, 2012 | 07:27 PM
hawwk's Avatar
hawwk
Originally Posted by shooter5074
Old School........ cloth friction tape, and hair spray. Trust me, you'll have to cut the grip off.
Wrap the bar in a spiral from the inside working out to the end of the bar. Tuck the tape into the open end of the bar. Spray the tape and inside of the grip with hair pray.... lots of hair spray ..... twist the grip on.
Did it this way a year ago when I changed the bars. Grip still hasn't moved
Old Apr 10, 2012 | 07:32 PM
mrfikser's Avatar
mrfikser
I use pvc pipe cement....get it at the hardware store.........
Old Apr 11, 2012 | 03:08 PM
TWIN CAM 96
That sounds like a good deal there.
Adam Hoag
General Topics/Tech Tips
Jul 2, 2018 07:33 PM
trike1
Feb 17, 2014 09:58 AM
DeneFXDWG
Apr 11, 2011 12:38 PM
HDF Tech
Sep 11, 2008 04:32 AM
Koppster
Dec 5, 2007 07:54 AM
