Brake job screwed up
Old Apr 12, 2012 | 04:01 PM
skratch's Avatar
skratch
Originally Posted by Born2cure
By chance anyone know the part number for a rear caliper 08 ultra, not in catalog.
44080-08
http://partsfinder.onlinemicrofiche....dmc&A=663&B=30
Old Apr 12, 2012 | 04:18 PM
FastHarley's Avatar
FastHarley
Former Sponsor
From what I remember. that Allan head bolt that holds the pads in are a standard right hand thread and not left hand. Here is a pdf that I did a while ago to help others. That pin has a spring clip on it that must be removed first or it threads inside of the caliper and is stainless steel wire.
This is what I got out of your post. If you are in the South FLA area give a call and we can mill out the bolt, re thread it and send you on your way.
Brembo Brake Maintenance Guide PDF Download
If I am reading this post wrong than I apologize.
Old Apr 12, 2012 | 06:08 PM
piasspj's Avatar
piasspj
First thing I thought of when I read the post.
Old Apr 13, 2012 | 04:51 AM
Born2cure's Avatar
Born2cure
Thanks for the heads up and the web search anglerod sent email to him see if he still has. Not to far from my house.
And skratch thanks for the numbers. Infor is appreciated
Old Apr 13, 2012 | 07:19 AM
steelerdude1's Avatar
steelerdude1
Just a thought here, can you take the caliper off and grab the pin from between the brake pads with a pair of needle nose vise grips and turn it out that way?
twp98
Apr 20, 2016 06:31 PM
penmaker
2014-2024 Touring Models
13
Jun 24, 2015 11:31 AM
SC-Longhair
Sep 20, 2011 10:50 PM
Lone Watie
Feb 18, 2008 12:35 PM
michaelbarry
Aug 31, 2007 04:40 PM
