How to troubleshoot starter??
Old Apr 12, 2012 | 08:23 PM
springer 03's Avatar
springer 03
Default How to troubleshoot starter??
I walked out of the Subway shop about an hour ago and turned the ignition on to my 09 StreetGlide. The usual fuel pump noise and I hit the starter button and nothing. I had just shut it off 10 minutes before after a short ride to Subway. I managed to get it to a hill and bump-started it and made it home. After removing the sidecover I can hear the starter relay activate but the starter doesn't make a sound. The starter is only a month or so old and has worked fine up to now. I have uplugged the starter connection and replugged it to no avail. Any ideas??
Old Apr 12, 2012 | 08:47 PM
hog-doc's Avatar
hog-doc
Have you checked to make sure your battery cables are tight? Ive seen loose cables cause your symptom!
Old Apr 12, 2012 | 09:54 PM
mkguitar's Avatar
mkguitar
yup check your cables at both ends ( tight and clean) and that battery is fully charged, then:
the green wire at the solenoid comes from the stater relay.
with a test light or meter you should see 12 volts there when the starter button is pressed.
if not
then the problem is in the wiring, relay, starter button/ kill switch, and on newer models maybe a neutral, or clutch switch too
but you can hear the relay clicking so all that is probably good, if you have no power at the green wire when you hear the relay, then try swapping relay ( on many models the relay is a simple auto part store swap).
if you see 12 volts at the green wire and the starter is not operating, then you have to check the solenoid
the solenoid is easy to service, if you ever did a chevy, the H-D is much the same.
mike
Old Apr 13, 2012 | 09:03 AM
springer 03
if not
mike
Thank you for the straight -forward answer. I just came in from the garage and I am getting 12 volts on the green wire. I'll be pulling the starter and checking the solenoid next although I have no idea what I'm doing.
Old Apr 15, 2012 | 05:57 PM
springer 03
Well I pulled the starter and took the end cap off the solenoid. Everthing looked fine and clean. I decided to take it to the local starter repair guy. He put a 12V clamp on the big stud and the other clamp on the starter flange. He jumped from the 12v clamp to the solenoid connection and it spun to life. Nothing wrong with the starter. Reinstalled the thing and reconnected all the wires and battery. I hit the starter button and it works. I'm not sure what I fixed if I fixed anything at all but my guess is either the ground or the hot from the battery. I'm nervous everytime I go to start it now although I did throw a short piece of #12 solid copper in the saddlebag to jumper the thing if I have to.
Old Apr 15, 2012 | 06:57 PM
buttmonkey's Avatar
buttmonkey
Time to buy one of the plunger end caps. I have had one on all my bikes as far back as I can remember. Peace of mind from just the problem you described. You can also drill hole in the end of the solenoid switch. stick a rubber plug in it. Then all you have to do is pull the plug and stick a screwdriver in and push the plunger
Old Apr 15, 2012 | 08:12 PM
springer 03
I did push the plunger in when I had the end cap off. I didn't do it for any reason other than to do it. What exactly does that do and what symptoms have you used it for?
Old Apr 16, 2012 | 04:26 AM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Sometimes new starter motor brushes are a bit too thick or their corners too sharp. You can rub them against fine sandpaper or use a metal file to adjust the play.
Old Apr 16, 2012 | 03:29 PM
buttmonkey's Avatar
buttmonkey
If you take off the 5 sided cover over the end of the starter solenoid, you expose the solenoid plunger. Pushing in on the solenoid plunger (what the solenoid does when you push the starter button) closes the large copper contacts, energizing the starter motor.
This cover allows you push in the plunger to engage the starter.
Wampa Stomper
Shovelhead
Sep 26, 2015 06:58 PM
springer 03
Apr 13, 2012 01:11 PM
pedulla242
Mar 2, 2011 11:12 PM
TexasCowGrower
Sep 20, 2010 10:44 PM
wfbailey06
Sep 10, 2010 01:54 PM
