Replaced clutch cable-- what did I do? Or what am I supposed to do?
This winter I put on 10" monkey bars. While riding this spring, I realized I needed a little longer clutch cable as clutch wouldn't engage when turned sharply one way or the other. So I picked up a +3 cable from J&P (right up the road) on their recommendation and installed it tonight. Really (for my experience level) went pretty well until the end when I'm trying to adjust the cable. I can't get it adjusted enough to Get rid of enough slack to make the lever work. What am I doing wrong or what am I supposed to do?
Things I'm thinking..
-do I need to adjust the clutch??
-is the ball/ramp thing somehow messed up...it sure seemed right, checked it multiple times
-did I buy too long of a cable? Doesn't seem like it...fits well.
As always...thanks guys...and I sure can't wait until I'm good enough that some of this stuff becomes easy.
One thing you might want to look at is whats called the travel of the cable. Sounds like the travel might be to long for what your needing. The cable you should be looking for is a
+4 with a length of 66 11/16" with a travel of 3 1/2.
or
+6 with a length of 68 11/16" with a travel of 3 1/2
From what I gathered:
1.) create slack in cable by collapsing (thread to each other) the cable adjusters.
2.) in primary, loosen locknut and lightly seat the thread adjuster.
3.) turn out thread adjuster between 1/2-1 turn (I use 3/4)
4.) tighten down locknut, making sure thread adjuster stays in place.
5.) pull lever 2-3x to set ball/ramp (no more than 3)
6.) adjust cable so the clutch cable ferrel pulls out no more than 1/16-1/8" from clutch lever. tug around on cable to make sure slack is removed on this adjustment.
That's about all I know ...
Troop, and others ... First step is to LOOSEN cable adjusters and allow slack in cable.
You don't REMOVE the slack until the mechanical adjustment is set correctly at the clutch.
You take the slack out with the adjuster after you have set the correct internal contact, and back off the internal adjustment whatever the manual tells you, often about 3/4 of a turn.
By tightening the cable adjuster before the internal adjustment is set will defeat your ability to adjust the internal contact correctly.
I installed a set of 12" with a +6 a couple years ago.. I'm at the very limit when it comes to travel. After correctly adjusting at clutch I have to back my cable adjustment out nearly all the way as well.
I used Motion Pro as that's all I could get without waiting 3+ weeks. For some reason Magnum, Barnett and another that I can't recall were all backordered.
Ha .. That's exactly what I mean't by describing the collapsing of the cable but worded it wrong. Good catch/I corrected
ok, so it sounds like i do need to adjust the clutch on the primary side. i was just assuming (wrongly apparently) that if i was just changing the cable i wouldn't have to go through that. that sounds a little tricky....i'll read up on it.
as far as travel and the cluth cable. here is the one that J&P recommended for me. He said it's a dyna cable, but the same thing as street glide, only 3 inches longer that FLHX stock.
would anyone be able to confirm that having the wrong size cable isn't the reason for my problems before i take the inspection cover off and tackle adjusting the clutch.
It actually is a pretty simple task and it only takes about 15 minutes. Give it a try before replacing the cable. Tip is if you don't have upright stand, put a 2"x4" under jiffy stand to get bike upright as possible. No primary fluid will spill out this way. Also, a socket works better on the locknut vs. a box end wrench (spark plug socket is great).
According to the part number, the cable you bought is 69 11/16 in length with a 3 in travel. Cable is a little long for what you need but the travel is shorter. With a shorter travel you should be able to get it adjusted, but with the shorter travel it might not fully disengage the clutch. Do you have the cable they removed from your bike?
