I vote for MCC too. They can lower your seat 3" if you want for less than $100 plus put in memory foam too boot. Add memory foam for the ol and seat heaters front and back and it's still under $500. Sme of the best mods I've done.
I put the Road6 lowering kit with good success....do an ebay search (road6 customs lowering kit). As long as you dont go too lower ( kit will lower up to 3") it does the trick well with RKs, not so much on SGs or RGs.
This system will get you a 3 inch drop while keeping the stock suspension. It can only be installed at HD dealers that are set up and trained to do the job. Not many are set up to do this yet, but I know that Kutter HD in Janesville, WI is.
