Ignition Switch Pulled Off???
Old Apr 13, 2012 | 08:13 PM
JHC210's Avatar
JHC210
Default Ignition Switch Pulled Off???
Ok, just parked the bike and turned the switch to off and the ignition switch pulled up. I pushed it back down and turned the wheel and locked the fork. Well, that was it. The switch stayed in lock position but I could straighten out the front. Long story short, I finally was able to unlock the switch but the whole switch lifted out, including sping. How do I put the switch back in so it functions properly? Also need to know how the heck did this happen? Of course today is Friday the 13th!
Old Apr 13, 2012 | 09:00 PM
Potato_Potato's Avatar
Potato_Potato
This is a good vid to learn how to remove the switch but yours is likely broken. I'd remove it and closely inspect it for obvious problems.
http://www.youtube.com/watch?v=7-QBH1SFyzo
Old Apr 13, 2012 | 09:04 PM
DTTJGlide's Avatar
DTTJGlide
It's a 2012, take it to the dealer & tell them to fix it, that's what the warranty is for.
Old Apr 13, 2012 | 09:11 PM
robertg's Avatar
robertg
I just has one that would do the same thing. The screw holding the shaft to the **** came loose and the **** would wobble enough to pull out. There is a hidden screw under the **** decal that may need to be tightened.
Old Apr 14, 2012 | 04:48 AM
HD101st's Avatar
HD101st
I agree its probally broken because there is a certain sequence you need to preform to remove them better off taking to dealer
Milkman424m
Apr 28, 2020 11:17 AM
hardheaded
Sep 4, 2018 10:30 PM
Watchfuliz
2014-2024 Touring Models
16
Jan 17, 2015 09:40 AM
bearammus
Mar 6, 2014 08:08 PM
Rznkane
Dec 29, 2012 01:16 PM
