The 04 is different than the 07's which have to be programed at the dealer. when they program it they need all the fob's there to do it at the same time. When I needed a new fob the dealer I bought it from programed it for no charge cause I bought it off them
Sorry, didn't see what year bike they had. Since it was their first post, I didn't research much.
This must be done when you buy a new button type key fob for the alarm if you loose one.
I assume you know your personal entry code using the directional switches and the key switch to activate , if not , it's in the owners manual.
If you never set the code,the dealer can help you out here.
1. Set run switch to off
2. ign to acc
3. hold both turn sigs till lights flash
4. use left turn signal to enter number by pushing 7 times
5. use right turn signal as enter key
6. repeat until all 5 are entered and you hit enter
lights should flash and you should be OK.
KEY FOB ASSIGNMENT
The key fob on TSSM motorcycles must be set so it will operate the alarm system on the vehicle.
This assignment must be completed with no pauses between steps greater than 10 seconds.
Turn the ignition OFF after all key fobs have been assigned.
The programming mode will also exit after 60 seconds has elapsed without detecting any fob signup messages
or turn signal switch activity.
Two key fobs may be assigned to the TSSM.
The first successful attempt to program a fob will disable all previously assigned fobs. If a second fob is to be programmed, it must be done in the same programming sequence as the initial fob.
