Another Speaker Question
Old Apr 26, 2012 | 12:28 PM
goosehntr's Avatar
goosehntr
What about wiring, and adapter rings. I have the Chrome accent rings on the stock speakers. Also is there a depth issue for the polks mounting the rear speakers.
Old Apr 26, 2012 | 12:56 PM
goosehntr's Avatar
goosehntr
Also what about running this big of an amp with the stock stater, anyone have issues with that at all.
Old Apr 26, 2012 | 02:38 PM
Nightrain04's Avatar
Nightrain04
Just peel the stock grills off the speaker mounts and put between 6.5 adapters and fairing. Mine worked great with Dragonfly adapters.
Old Apr 26, 2012 | 04:40 PM
GLACIERPEARL's Avatar
GLACIERPEARL
I run 1200 watts worth of amps on my Ultra, with no mods to the charging system. Don't worry !!
Old Apr 26, 2012 | 06:32 PM
Fxstsb6's Avatar
Fxstsb6
Default Question for Murph about the RF300X2
Where did you set the gain on the amp? I am looking to enhance my sound on the 98 FLHT I putt around on........... Thanks, Fxstsb6
Old Apr 26, 2012 | 07:31 PM
wjl24's Avatar
wjl24
You can't (or at least shouldn't) run the Polk MM series with the PBR300X4 4 channel amp. It's is rated for 4 ohms ONLY. I called RF to verify this. I'm going to run biketronics titan II in front and Polk 6.5" DXI series in the rear. The Polk DB and DXi series are 4 ohms, although the MM is a better speaker it is 2.7 ohms.
Old Apr 27, 2012 | 06:09 AM
goosehntr's Avatar
goosehntr
Ok, so is there a good 4 channel amp that will work with the Polk MM speakers. And will the polk with an amp sound better than the hog tune and the boom audio?
Old Apr 27, 2012 | 06:11 AM
jjnoble's Avatar
jjnoble
I can't answer about the amp, but yes, the polk will sound better than the hog tune and the boom audio speakers.
Old Apr 27, 2012 | 06:27 AM
homebru's Avatar
homebru
3rd Gear
ARC audio has a 4 channel amp that is compatible with the Polk MMs. I'm getting ready to install their 2 channel amp in my fairing. I am currently running the MM6501 component speakers. No fitment issues at all.
Old Apr 27, 2012 | 07:05 AM
wjl24's Avatar
wjl24
J&M and Arc make the 4 channel amp that will run 2 ohm speakers. The amp is big and requires some extra mods to get it to fit. You need to remove some gauges and cut bezels. Also pricey.
The PBR300X4 can be bought for $140.00 on Amazon. The biketronices Titan II can be bought for $199.95 at Direct Harley or Eastern Performance Cycle did a price match when I called them and had them in stock. The Titans come with the adaptors.
I'm still looking for a good price on the DXi650 Polks for the rear.
Hogtunes Big Ultra kit can be bought around $400.00 complete with 4 speakers, amp and wiring . Some people are very satisfied with that. It will be louder and clearer than stock for sure.
