O-Rings
Old Apr 27, 2012 | 01:15 PM
SteelCityRider's Avatar
SteelCityRider
Default O-Rings
What is the proper O-Ring size for the oil, tranny and primary? I would like to buy a few and keep them around. It is hard for me to get to the dealership, local hdware store should have them. They are not anything special are they?
Old Apr 27, 2012 | 01:22 PM
mkguitar's Avatar
mkguitar
yes, they are a petroleum resistant viton.
just get a bunch at the dealer next time, yes they cost more but you can be sure that the rubber won't degrade.
when tightening the plug, don't go over tight, i get many uses- but I replace if flat-spotted or visible tears, damage.
Mike
Old Apr 27, 2012 | 01:23 PM
grbrown's Avatar
grbrown
I thought O rings must be available in a few standard sizes and be widely available. But I learned years ago, trying to find the right size, that it was easier and cheaper in the long run to get the correct ones. Now it may indeed be that those you want are stocked more conveniently and I look forward to other replies! Fingers crossed.....
Old Apr 27, 2012 | 01:53 PM
fabrik8r's Avatar
fabrik8r
Industry size 013, go with the Viton, they are good to 400 degrees, Buna-N is only good to 250. $7.72 per 100 at McMaster Carr.
http://www.mcmaster.com/#rubber-o-rings/=hah9a2
Old Apr 27, 2012 | 02:01 PM
Moneywoes's Avatar
Moneywoes
$.08 at oringsusa
http://www.oringsusa.com/catalog/pro...5t1knq28nbl6i3
Old Apr 27, 2012 | 02:34 PM
speakerfritz's Avatar
speakerfritz
when my 07 was stock...it had no o-rings...used to turn the plugs in by hand then once they felt tight....turned them 1/16th of a turn more...never had leaks or seeps. Later I ordered some upgraded magnetic plugs...they came with o-rings...I installe the same way...soon as they feel tight by hand..1/16th of a turn more. Been reading the warnings about the sump plug....supposedly...too tight on that one will crack the hole....never seen it happen or heard of anyone who cracked their hole...but you never know.
Old Apr 27, 2012 | 02:50 PM
Jackie Paper's Avatar
Jackie Paper
Soft rubber buna n. Probably best to change ever time but I scope it good and if it looks good, I have used them many times more then once. However if I get a drip, I replace it next time. Would never use one twice when I work on others. $1.00 cheap insurance....
Old Apr 27, 2012 | 02:52 PM
fabrik8r's Avatar
fabrik8r
If your 07 didn't come with an oring on the drain, it's only because someone on the assembly line F'd up, it should have had one.
Old Apr 27, 2012 | 02:54 PM
RHillbilly's Avatar
RHillbilly
Get mine at home depot been running them 3 yrs no problem change it every oil change
Old Apr 27, 2012 | 03:03 PM
fabrik8r's Avatar
fabrik8r
Great pic, that also shows a cross section view of the very narrow tapered land that the oring seals on in the pan, which is why a helicoil can not be used to repair a stripped drain plug, because that sealing land would be completely removed with the ovesized helicoil tap(sorry, little off topic)
