Last week I installed my Jackpots. I brushed on some High Temp Anti Seize around the outside end of the headpipes, then slipped on the mufflers and torqued the clamps to spec. Is this standard procedure or should I have used something else - or nothing else?
I haven't been able to ride since the installation, since the weather here on the East Coast has been rather rainy lately.
I do pretty much the same thing every time (and there have been many times). Except for the anti-seize, or the proper torque (or even new clamps for that matter)...
If you torque to "good and tight" you could very well get "good and broke". Use a torque wrench and do it right.
Very sound advice. There is a reason for torque specifications and sequences. Whenever those specs are available, no compromise, I follow them. It's your bike, so do as you will.
If you are talking about those torca clamps... torque specs won't be worth a crap after they are used more than once because they stretch... tighten the crap out of them, If you are talking about the studs that come out of the heads then anti seize and tight to torque then recheck after a ride.
As long as you slid the pipes on just past the crimp groove, used HT silicone & torque to spec - should be good to go. Note: Liquid copper is your friend...never had exhaust leaks since using this suff (great product). Nothing more annoying than exhaust leaks...
Sometimes you can get away with reusing the muff clamp if it was originally torqued at the bottom end of the torque range. Like it or not, they are single use items. But lots of guys (not you) would rather do a job over than spend the $14 needed to purchase two new clamps and do it right the first time. Using the silver anti-seize is good engineering practice in that it provides easier removal of the mufflers after years of being clamped to the same header. Seized mufflers are not easy to remove and the force required sometimes upsets other clamps and fasteners in the exhaust train.
I'm certainly no expert, but I doubt that very many can feel what 38 to 43 ft pounds of torque feels like, so to say that you just snug them and look for leaks is a pretty good guarantee that you will find leaks. Maybe not today, but somewhere out there in the middle of a ride when it is least expected (or wanted), the rattles and leaks will start. Been there done that and now know better.
