Originally Posted by Vi ctor Afilados Cerrajeria Palomo
i have same problem, im trying to solved it with sert.
in the end, did you solved it?
i have dyna low rider s.
thanks
While your search efforts are appreciated IMO you may be further ahead to start a new thread as opposed reopen one that was started 11 1/2 years ago. JMO.
OP, you never did say if it's fuel injected or carbureted. If it is a carb, it might be worth a look to see if the accelerator pump is working correctly.
First post was from April in 2012. So that must mean you're from the future.
Has the MOCO solved the transfer and sumping issues yet?
My 04 does the same thing. I may go for a month without it happening, and then have it happen three times on one day.
Most typically, puttering along, especially on dirt where I'm on and off the throttle quite rapidly. It has never caused me a problem, and the bike is somewhere just south of 60k.
fwiw, mine is mechanically stock with a high flow intake filter and plate. I've no idea if it has a tune on it.
