Ideas for Lights on Tour Pak
Old Apr 28, 2012 | 08:57 AM
StreetKing's Avatar
StreetKing
Default Ideas for Lights on Tour Pak
Just got my Tour Pak back from the painter for my RoadKing. I need some ideas for a nice clean look for a light set up. Not to much,simple but nice. LED's Thanks
Old Apr 28, 2012 | 11:46 AM
ThunderBueller's Avatar
ThunderBueller
I was on the fence for a long time in adding the LED setup from Harley and finally decided to give it a try. I LOVE how it looks with the color-matched frame. I watched ebay for quite a while and lucked into one for a real good price. I added a Ride Time Technology module that makes all the lights run/brake and the corners are turns. Stock function is just running lights with center brake light.
Old Apr 28, 2012 | 12:01 PM
mkguitar's Avatar
mkguitar
if you think you will end up with a rack, the airwing rack has an LED kit which works very well for run/brake.
some light kits may decrease interior space.
Mike
Old Apr 28, 2012 | 12:08 PM
jeffreydsilver's Avatar
jeffreydsilver
Default Harley LED Setup!
I added the Harley LED setup to my tourpak. The only mistake I made was not having it painted before installation. My bike is vivid black and the plastic framework of the light is flat black. I figured it would look good, and it does but, it would have looked outstanding had I had it painted.
The stock function of my LED setup was a conversion setup - ALL lights on when the bike is on - All lights brighter when applying the brakes and full turn signal fuction of the outer led's
Old Apr 28, 2012 | 12:43 PM
glide2005's Avatar
glide2005
I figured, I want as much light on the rear as I can get to keep the cagers off my ***. 1939 Ford led's and a 12" third brake lite from a suberban. All light up when braking, just the 12" doesn't stay on all the time. The rest also work as turn signals.
Old Apr 28, 2012 | 12:49 PM
StreetKing's Avatar
StreetKing
Good choices. Any others? Plasma rods? Something different.
Old Apr 28, 2012 | 12:59 PM
bklynbob's Avatar
bklynbob
www.whelen.com Strip-Lite
www.radiantz.com
the airwing lights aren't very bright...............
Old Apr 28, 2012 | 02:05 PM
Razorback's Avatar
Razorback
Figured them pointy Caddy lights would scare them away....
Check these guys out. Lots of ideas. I'm looking at a few also. I intend to keep 'em hidden until they're on.
http://www.customdynamics.com/ click "cycle products" at the top >> http://www.customdynamics.com/motorcycle_lights.htm
Old Apr 28, 2012 | 03:43 PM
Airborne Limited's Avatar
Airborne Limited
I recently added a Custom Dynamics 75 LED strip to my Tour Pak. You can see the post about it here It was a cheap ($20-30) and easy install. I originally just added the light without the convertor because I only wanted it as a running light, but decided to add the convertor ($5 more) so now it is a running/brake light.
Old Apr 28, 2012 | 04:10 PM
Harleypingman's Avatar
Harleypingman
Since you have a RK, you won't have a tour pak harness to use for the run/brake wiring regardless of your choice for LED's; you'll need to use the accessory connector under the seat or, splice/Y-connector for the rear lighting on the bike.
Another vendor to consider is ridetimetechnology.com.
Carl
