Why use pushrods?
Old Apr 29, 2012 | 09:54 AM
grbrown's Avatar
grbrown
Most mass produced engines that use overhead cams use them for marketting purposes, just as Harley uses pushrods for the same reason. Any engineering considerations are secondary. Auto engines use them to get lightweight valves to reduce parasitic losses, in other words to improve exhaust emissions and economy. Production motorcycles were influenced by factory racing bike design a few decades ago and while sports bikes benefit from OHC the plain fact is that most bike makers use them today for what have become traditional reasons.
Old Apr 29, 2012 | 12:17 PM
DrPlastic's Avatar
DrPlastic
Not all Chevy V8s were push rod engines....the 1990 Corvette LT5 engine was a DOHC 4 valve per cylinder engine! It was designed by Lotus and built by Mercury Marine. It was produced from 1990 thru 1995.
Old Apr 29, 2012 | 12:27 PM
TO34's Avatar
TO34
It does make for a simple motor to work on, I can turn a wrench on it BUT something is going to have to give with the EPA locking down. What I can not understand is why they have not upgraded the rocker arms.
Old Apr 29, 2012 | 12:39 PM
Gunslingertom's Avatar
Gunslingertom
Originally Posted by shortride
I have often wondered why someone has come up with a well-timed electronic solenoid to operate the valves. It would take the mechanical load off of the engine. The only potential draw-back would be that electronic solenoid would draw a lot of amps to open and close the valves.
Enter Cadillac. They've been working with electronic and hydraulic actuators for lifters for a number of years. The implications are unbelievable. Imagine changing your lift, duration, etc from a control box or computer for whatever type of driving your doing at any given time. With that kind of control, coupled with literally no friction from a camshaft, you could run unbelievable E.T's and still have a car that would get very high gas mileage.
Maybe they stuck with the push rod V-Twin because that much timing chain WILL fail and a failure is catastrophic. No different than a TC chain failure except you can convert to a gear drive on a TC motor. I hate long timing chains.
Old Apr 29, 2012 | 01:36 PM
racklefratz's Avatar
racklefratz
Originally Posted by iceman5218
Why does Harley not use overhead cams?
Overhead cams are a vastly superior design, which is why it has become the modern industry standard. A brand new 110 ci Harley will make around 80 hp, and only low 90s hp with Stage 1 mods. By comparison, a Honda Goldwing which is 1,800 ccs, (equivalent to 110 cubic inches) will make 118 hp out of the box, no mods.
Reason for Harley's pushrods? Nostalgia and styling. It's what makes a Harley, a "Harley". And Harley Davidson has elevated "nostalgia and styling" to an art form.
Old Apr 29, 2012 | 01:40 PM
iceman5218's Avatar
iceman5218
Ok, since someone else brought this up, how do some of the other bike makers get away without OHC and no pushrods. I came from a VTX 1300 and would still love to have a 1800F Spec3. I know the 1800 is an apples to oranges comparison with the 96", but how did my 1300 create the torque numbers it did without the cams (probably should ask this on the VTXOA site)?
I'm playing devil's advocate because if I could only have one bike, I'm going to keep my RK.
Old Apr 29, 2012 | 02:04 PM
DavidStiebel's Avatar
DavidStiebel
One item not mentioned here, the engine,
1. the push rods raise oil to the heads to cool them and
2. they never need adjustments.
Why would you want to screw-up a perfectly good design?
Many are bringing up the corvette which uses old-school, proven school, performance design, low r's high torque Vs high r's low torque.
Which pushes you down the road, RPM or TORQUE?
Also high R's means the absolute requirement for water cooling, and with that there goes the Harley air cooled engine with low r's rumble. It's inevitable they will make a pink sportster for the alternate scene.
Old Apr 29, 2012 | 03:06 PM
Scratt's Avatar
Scratt
First thing, I look at DrPlastic's post and just keep thinking ***!.....sig pic
OK back to thread, Harley has a signature motor (V Twin), if they change over too fast they will lose customer's, It's the feel/look of an Old School Harley that sells. Sooner or later they will have to go electronic/ computer driven everything and water cooled (sucks) to meet epa standards.
I'll keep my push rod, solid mount EVO as long as they keep selling gas.
Old Apr 29, 2012 | 07:00 PM
V2Evo96's Avatar
V2Evo96
Originally Posted by senna
Corvette still uses pushrods, they perform pretty well. I like the fact HD uses pushrods, reminds me more of a hot rod.
.. and a radial aircraft engine. I have a work colleague into old aircraft and he has an old Avro radial engine bi-wing. I love to hear that sucker light up!
Old Apr 29, 2012 | 09:37 PM
senna's Avatar
senna
And how's the connecting rod arrangement on that radial.
