New Exhaust.... Tuning necessary?
Old May 1, 2012 | 09:57 AM
82husky's Avatar
82husky
3rd Gear
Default New Exhaust.... Tuning necessary?
When I was in Laughlin last weekend I bought a Freedom Performance Exhaust system and had it installed. The tech's said my 2011 Electra Glide didn't need any tuning and that after some riding the bike would "adjust" to the new exhaust. The bike is basically new and only has about 1000 miles. I have a few more miles since the installation but it pops and tends to load up at slow speeds. At speed or under acceleration it runs fine. Do I need to do any thing else in terms of tuning to improve the performance?
Thanks in advance for any advise...............
Old May 1, 2012 | 10:09 AM
Keithhu's Avatar
Keithhu
Improve performance and requiring a new map are 2 different things.
Generally the ECM will adjust to new pipes AND new AC (heresy to a lot of people on this board, I'm aware), but if you want it to run cooler and squeak a bit better performance out, you'll need some sort of fuel management system which will re-map your bike. Lots of options there, but also a lot of reading that you can do on the forum about it.
Old May 1, 2012 | 10:30 AM
Gearhead3's Avatar
Gearhead3
Your ECM should compensate but it will run just as lean as before. That being said, air cooled engines cannot run properly at the lean A/F ratios needed to meet the EPA's emisson standards. (approximately 14.6-14.7:1) They sometimes have lean surge issues, they run hotter than they should and all around throttle response is lacking. That's why most of the guys on here (with stock setups) run their bikes at higher RPM's around town and out on the highway. Their throttle response at 2-3,000 RPM's is mushy/soggy at best. It's not crisp like it should be. You really should get some sort of tuner and get the A/F down to around 14.2:1 in the cruise range and under full throttle conditions about 13:1. Your engine will be much happier at these ratios and you'll notice a marked improvement in all around rideability.
Old May 1, 2012 | 02:15 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
u don't have to tune it,but imo i would tune a completely stock bike,it won't make a bunch more power but it will run cooler less surging stumbling and pinging.
Old May 1, 2012 | 02:48 PM
Tn.Heritage's Avatar
Tn.Heritage
Do yourself a favor and have it tuned. I just spoke to the Steve at fullsak and he just said the freedom guys were putting on exhaust and telling that you didn't need it tuned. Get it tuned.
Old May 1, 2012 | 02:58 PM
SSTuner's Avatar
SSTuner
Get it tuned. These bikes run way to lean from H-D and with the new exhaust it may run a little leaner. Get a "box" or get it Dyno tuned, you will and the bike will be much happier.
Old May 1, 2012 | 07:38 PM
TUCCI's Avatar
TUCCI
I'm going to throw a cog in this thread and suggest an XIED, that's what I did and I don't have any surging, stumbling or pinging...oh and it runs like a raped ape at any speed, any gear.
Old May 1, 2012 | 09:04 PM
Lawdawg's Avatar
Lawdawg
I have always been told no. When I bought my 09' Ultra (new) it had Rineharts already on it from the dealer, no high flow a/c or remap.
T^2
Feb 9, 2018 12:49 PM
Mufasa
Jul 26, 2013 07:46 PM
fredwalters
Sep 18, 2012 02:30 PM
c50plus
Jun 22, 2011 06:03 AM
soundman
Mar 29, 2009 08:42 PM
