Eitms
Old May 1, 2012 | 10:26 AM
Rickr01's Avatar
Rickr01
Default Eitms
Can anybody tell me if the PCV renders the EITMS inoperative? Mine does not seem to be kicking in lately?
Old May 1, 2012 | 10:28 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Roll your throttle forward when sitting still and see if it's engaged. You might have accidentally turned it off.
Old May 1, 2012 | 10:34 AM
Gearhead3's Avatar
Gearhead3
Mine's fine, but as shooter stated double check it to make sure it's turned on.
Old May 1, 2012 | 10:49 AM
TUCCI's Avatar
TUCCI
I have to check to make sure mine is enabled once in awhile cuz its not as pronounced as it was last summer but then the inferno is not quit here yet!!!!
Old May 1, 2012 | 12:21 PM
Gunnysgt's Avatar
Gunnysgt
The PCV should have no effect what so ever on the heat management system. To check it, turn on the ignition, make sure the run switch is on. Roll your throttle forward (Off) and hold it a few seconds. If the cruise light comes on green, it's on, if it comes on yellow it's off.
Old May 1, 2012 | 12:25 PM
shooter5074
From the online manual.... a little wordy, but pretty much what Gunny said.
Enabling/Disabling EITMS
Enabled: The EITMS engine cooling feature will automatically activate whenever the vehicle comes to a complete stop and is idling during elevated temperature conditions. Even with the feature enabled, it may not activate under cool riding conditions.
Disabled: The EITMS feature is not active under any conditions.
Vehicles are delivered from the factory with EITMS disabled. EITMS can be enabled or disabled by the rider by performing the following procedure.
Turn the ignition switch to the ON position and push the engine OFF/RUN switch on the right handlebar to the RUN position (do not start the motorcycle).
Push the throttle to roll-off position and hold.
See Instrument Lamps. After approximately 3 seconds, the cruise indicator lamp will either flash green (EITMS enabled) or red (EITMS disabled).
NOTE:
A flashing lamp indicates the EITMS setting. A solid (non-flashing) lamp indicates the cruise control setting.
Repeat the procedure as needed to enable or disable EITMS.
NOTE:
The EITMS setting will remain in effect until it is changed by the rider or dealer. It does not have to be reconfigured at each startup.
Old May 1, 2012 | 02:13 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
if your pcv map is on the rich side your bike should run cooler and not get hot enough to activate the emits as easily.
Old May 1, 2012 | 02:34 PM
mrfikser's Avatar
mrfikser
NOTE:
NOTE:
just as a side note...the bike can be running when you do the above...
Old May 1, 2012 | 03:03 PM
Rickr01's Avatar
Rickr01
Thanks everyone. I know how to activate and deactivate the EMITS. Mine indicates it is active. However, it has not come on since I installed the PCV with the new map. This answers the question I believe. It is definately running richer than before. Thanks to all that responded. Rick
Old May 1, 2012 | 07:04 PM
Potato_Potato's Avatar
Potato_Potato
It doesn't work with SERT or it may be that it has to be turned either on or off with DT, can't remember.
marcparnes
May 31, 2013 02:55 PM
JayOhh
Oct 14, 2012 03:13 PM
rleggs
Nov 27, 2011 08:44 PM
fireaxxe
Apr 8, 2010 12:05 AM
NAUIdvr1
Sep 28, 2009 07:47 PM
