I am leaving food on the table..andrews 37?
Old May 2, 2012 | 08:37 PM
JKCDN's Avatar
JKCDN
Thumbs up I am leaving food on the table..andrews 37?
Read post's until my eyes got blurry but did not find much on how a set of Andrews 37 cams perform with a new FLHX 103 versus the woods 555. My local tuner prefers the 37 and says they are more dependable than the woods 555 that I am also interested in. I am riding 2 up 90% of the time and want the bulk of my go-juice on both ends of the tach
I am adding a bassani road rage 777 and SE push roads as well. Most of what I read about the 37 is that it is not always the right cam but never the wrong one and primarily talked about in conjunction with 88's and 96's
The 555 does seem designed for modern heads and may make better use of my specific setup. Things like heat, mgp and sound are not issues for me. Dependability (I have just started the 5 year extended warranty) and shazaam are what I want.
Any advice?
Greatly appreciated.
JKCDN
Old May 2, 2012 | 08:38 PM
Cowboy Rob's Avatar
Cowboy Rob
Big Kahuna HDF Member
Subscribed.
Old May 2, 2012 | 09:03 PM
Steelknee57's Avatar
Steelknee57
I wouldn't go with the 37. I had one in my 95" road king , it didn't come on until about 2800 rpm.
I would go with an Andrews 26 for all of the 2 up you do.
You can email Andrews Cams and they will give you their recommendation too.
Old May 3, 2012 | 06:34 AM
nearmiss's Avatar
nearmiss
The andrews 37g likes a little compression. Andrews says 9.5-1 and some tuners recommend as much as 9.7-1. I have them on a 95inch with cc'd heads and it pulls strong just above 2200 and goes to over 6000. Nice flat torque curve.
Old May 3, 2012 | 07:50 AM
Neckball's Avatar
Neckball
I would ask the tuner for an explanation of exactly what that means.
Old May 3, 2012 | 10:51 AM
0ldhippie's Avatar
0ldhippie
I'm thinking more lift is a good thing and am going with 54h?
Old May 3, 2012 | 11:03 AM
Lowcountry Joe's Avatar
Lowcountry Joe
Andrews 26. Period.
Old May 3, 2012 | 11:15 AM
Ribitt's Avatar
Ribitt
Cool
+1 on the 26
Old May 3, 2012 | 01:01 PM
JKCDN's Avatar
JKCDN
Thanks for the replies everbody. I did check out the 26 and it seems to fit the bill. I guess I have an irrational fear that the cam is on the "older" side of things and that my 2012 103 could take a higher lift cam that would produce a wider powerband.
When I pushed the shop on why they prefer the TW37, the tech said that he has done so many installs with this cam that he could guarantee the bike to start every-time and that it would run cool.
$2814 incl tx for the cam. bassani rr 777, SE pushroods, TTS and 4 hrs on the dyno. This seem like a fair price?
Thanks again guys.
Old May 3, 2012 | 01:44 PM
djl's Avatar
djl
How long a cam has been in production shouldn't have any bearing on selection; the profile and performance are what counts. All the Andrews cams are quiet runners as compared to Mr. Woods cams that are not known to be quiet runners.
Almost everyone I have run across that has not run a variety of cams alwyas over cams their engine, without exception. You will not find a cam that will deliver the "bulk of their go juice at both ends of the tach"; you have to pick which end and which part of the middle you want to run in.
The stock heads don't flow much from .400" to .500" lift and are done at .500", so that's about all the lift one needs with stock heads. With the larger bore of the 103" engine, there will be enough compression to bring the 37's to life; they would like a bit more but they will respond. If you ride primarily solo, the 37 might be more to your liking; stron enough on the bottom, good midrange and will pull to the rev limiter. If you ride two up, the 26 would be a better choice; it's a very good cam for the touring models. JMHO
