2012 street glide header pipe glowing
Old May 3, 2012 | 04:11 PM
Brancajd's Avatar
Brancajd
Default 2012 street glide header pipe glowing
Just started up my bike after a few days of sitting...weather has been crappy here in Jersey.bike was running for only a few minutes and noticed the front head pipe starting to glow. Its only 60 degrees out and much cooler in my garage. I know its an air cooled motor but it shouldn't be that hot after only a couple of minutes right?
Bike had only 1000 miles on it...I have dbi fishtail slip ons and an Arlen Ness big sucker installed. What would make the pipe that hot only after a few short minutes if any?
Old May 3, 2012 | 04:20 PM
speedwaysteve's Avatar
speedwaysteve
Do you have any kind of tuner on your bike.maybe running on the lean side
Old May 3, 2012 | 04:27 PM
Duc's Avatar
Duc
That is where I was going, mentioned intake but not a tuner.
Definitely should not be that hot period more less that quick IMO.
Clif
Old May 3, 2012 | 04:34 PM
Aslan's Avatar
Aslan
Don't know what's causing it but it should not be glowing.
Old May 3, 2012 | 05:13 PM
Brancajd's Avatar
Brancajd
Don't have a tuner on it yet. It was almost starting to turn orange...I could tell it was getting hot.
Old May 3, 2012 | 05:21 PM
Duc's Avatar
Duc
Bikes are freaky lean from factory "emissions".
I would put stock back on until you can tune don't want to run lean for sure.
Clif
Old May 10, 2012 | 03:12 PM
78shovel101's Avatar
78shovel101
Ditto, go back to stock and see if it still glows. 2012 should still be under warrenty?
Old May 10, 2012 | 03:47 PM
FNGonaRK's Avatar
FNGonaRK
Not even broke in yet cuz. Not sure if I've heard of anyone doing a ac and exhaust upgrade without a tuner. I would avoid riding it until you could get one on there. Not good for the bike to run that lean. I would imagine that issue would be magnified during the break in period.
Old May 10, 2012 | 03:49 PM
mkguitar's Avatar
mkguitar
many do.
But reinstalling the stock restrictive air cleaner would be a useful exercise.
If the header can still be seen the be glowing, the EFI mapping should be checked.
extended idling--- the correct period to idle the bike in the driveway is until you feel the rocker covers warm to the touch- ride easy the first miles as the motor parts are expanding to tolerance.
as the revs come up oil pressure and volume increases, which helps to remove heat from the hottest parts of the motor
Mike
Mike
Old May 10, 2012 | 04:45 PM
longrideshields-1's Avatar
longrideshields-1
Premium Sponsor
+1 on the running lean. I'd check and make sure nothing is clogging the exhaust anywhere too!
__________________
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
