07 ultra will not start
Old May 7, 2012 | 10:32 AM
angelrod's Avatar
angelrod
crank position sensor
Old May 7, 2012 | 04:14 PM
nvsteve's Avatar
nvsteve
Originally Posted by btsom
Does this apply even though he said it cranks normally, just doesn't fire?
Oops, just went back and reread the initial post. Doesn't sound like he needs a new battery or has a bad ground. Maybe modee is on to something or the guys that suggested the CPS.
Old May 8, 2012 | 07:00 PM
hd159's Avatar
hd159
I done as scorpian said and disconnected the fuel line and hooked it back up and started up and runs fine, but I am goin to get new battery, thanks for the help
Old May 8, 2012 | 09:22 PM
jackhis's Avatar
jackhis
Good to know!
Old May 9, 2012 | 01:57 PM
longrideshields-1's Avatar
longrideshields-1
Premium Sponsor
glad you got it running!
__________________
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
Old May 17, 2012 | 01:09 PM
OdieHD's Avatar
OdieHD
Folks, I've had this issue off and on over the past 9 months. The last month or so, it has gotten worse. However, all I have to do is reach down and slightly move the connector. I don't have to disconnect it, just move it ever so slightly. I'm thinking that there may be an issue with the check valve in there but would like to know more info before I dig into the problem. Any ideas?
Odie
2008 FLHTCU
72,000 miles
Old May 17, 2012 | 01:18 PM
jackhis's Avatar
jackhis
Odie
2008 FLHTCU
72,000 miles
I am not familiar with your model, but I have a question: When was the last time you replace the fuel filter?
Old May 17, 2012 | 01:20 PM
Batman7349's Avatar
Batman7349
I've got 47,000 on my 07 which I just bought used. I just put a new filter in the tank and the dealer told me to replace the internal line and check valve since they can start causing problems at this age. I think it was about $47.00 for the check valve and hose. Of course by the time you buy the filter kit and have it all installed you'll spend $125.00 anyway.
Old May 17, 2012 | 01:25 PM
OdieHD's Avatar
OdieHD
Just had the fuel filter replaced for the first time about 1500 miles ago. The problem was there before the filter replacement but has become more frequent over the last two weeks (3-4 times)
Old May 18, 2012 | 08:03 AM
OdieHD's Avatar
OdieHD
Default Fuel Check Valve Replacement
So, this is starting to happen more often. So far, it seems like every other time I get on the bike. There are no codes, and again all I have to do is reach down to the Fule line and move it. So, I'm thinking about going ahead and replacing the check valve and fuel line. The service manual says you have to remove the Fuel Ring before you remove the Check Valve. Is it really necessary to remove the console and fuel ring?
HollowHeaten
Mar 28, 2019 07:07 PM
over60
May 15, 2015 11:37 AM
BoonDock_Saint
Aug 10, 2013 07:16 PM
HDnoob
Sep 26, 2011 10:03 AM
Ultrasweet
May 29, 2007 10:54 AM
