96" engine noise
Old May 7, 2012 | 11:29 AM
sloans4x4's Avatar
sloans4x4
Default 96" engine noise
I bought an 07 RoadKing, and it seems to have alot of engine noise at cruise speed. If you are on the throttle or off the throttle its doesnt seem bad. But on a 100mile ride yesterday I noticed it more at a steady cruise mainly around 40mph in 4th. But it does it in every gear at that certain RPM where there's really no load on the engine. Hard to explain, sounds like cam/lifter noise. But not sure. I didnt think the 96" had those issues.
What should I look for? Need some advice
Shane
Old May 7, 2012 | 11:35 AM
RHillbilly's Avatar
RHillbilly
Mine does it about 2200 to2800rpm nothing to worry about
Old May 7, 2012 | 11:44 AM
68 Shovelking's Avatar
68 Shovelking
Sounds like rocker arm clatter, which is typical.
Old May 7, 2012 | 01:35 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
Shane
My wife's '08 does this also.
You need to either, go faster, downshift to lower gear, or install some V&H pipes!
Years ago, when I first rode my '92 Heritage (before Stage I kit) I thought my engine had a rod knock! The dealer claimed the sound was due to a "hard cam". Once the new pipes were installed, the new noise covered the old noise and all was well.
Old May 7, 2012 | 05:38 PM
Jeffs386's Avatar
Jeffs386
pushrod engines are generally noisey........I wouldn't worry about it too much unless it gets progressively worse
Old May 7, 2012 | 09:19 PM
RK Joy's Avatar
RK Joy
I agree with the above. It's an air-cooled engine (no cooling jacket) OHV with external pushrods, bound to make a little music. I think my new engine does the same thing when unloaded. Under power, cruising down the road the only music I hear is that produced by my Pythons!!
Cohiba_Joe
Oct 26, 2020 08:17 PM
troop8520
May 3, 2013 12:35 PM
Macadoo
Aug 18, 2007 11:43 PM
Stumpman
May 14, 2006 11:43 PM
Johnny B Good
Mar 27, 2006 12:00 PM
