Doing the Stage 1
Old May 8, 2012 | 07:29 PM
Glockcubed's Avatar
Glockcubed
Default Doing the Stage 1
Here is what I am getting: (I am not a very good wrench)
V&H Duals 1802-0110
SE Ventilator A/C
SE super Tuner 32109-08C
DYNO
I already have SE Fatshotz slip-ons
Any input and suggestions would be greatly appreciated.
Old May 8, 2012 | 08:14 PM
aviscomi's Avatar
aviscomi
Take you time, you may need a buddy to help you align the head pipes to the manifold. Make sure you have exhaust gaskets, the biggest pain are the heat sheilds. Try not to run it very long until you flash the ECM with the SE map or till you bring it to your tuner.
Old May 8, 2012 | 10:36 PM
joflewbyu2's Avatar
joflewbyu2
V&H Duals 1802-0110
SE Ventilator A/C
DYNO
welcome. I am in Naples. I would change a few items. The OEM HD exhaust system is actually designed as a 2 into 1 with the dual being for looks. Most airflow comes out the right side and the left muffler is purposely more restrictive than the right. True Duals without a crossover take the design feature away. 2 into 1 exhaust or a 2/1/2 would give you better driveability and low end where most spend ride time. Either get a headpipe with the catalyst removed, FuelMoto pipe or Fullsac and keep the OEM mufflers if you like the dual look or get a 2 into 1. Also, look at the Heavy Breather intake for more performance and leg room. The ventilator stuck out and hit my leg while the HB angled forward and avoided my leg.
Old May 9, 2012 | 01:19 AM
BrownSanta's Avatar
BrownSanta
im not a big wrench myself and have been doing all the work myself. it probably takes me twice as long as a good wrench but i also take my time. also if you are going to work on your bike yourself get the service manual its a God send.
I also got the power vison instead of the sest so i didnt have to go to the stealer every time i needed to change something.
i did the folowing:
se heavy breather
v&h 2-1 high output propipe (couldnt wait for the stainless steel 2-1 from fm)
powervision from fm(dont get it from anyone else! lifetime maps)
Old May 9, 2012 | 01:31 AM
mkguitar's Avatar
mkguitar
V&H Duals 1802-0110
SE Ventilator A/C
DYNO
you asked;
true dual headers have less torque than headers which are connected by a crossover or a 2 into 1.
the V&H power duals can hit hard on right turns if you bike is lowered
the ventilator will supply more air than the motor could ever use ( most do), but it makes the plastic plug and wiring on the throttle body visible ( 9 0'clock).
the ness big sucker is about $120 on ebay from easternpc. chrome backing plate matches the chrome on the motor, uses the stock cover which hides the plug and wiring
super tuner: I'd rather have something adjustable for my money.
for tuning compensation I use nightrider.com xieds about $125
Fatshots; easily tuned to emphasis torque or horsepower, replace the "security screw" and gets some discs ( if needed, or endcaps) from ebay.
Mike
Old May 9, 2012 | 05:31 PM
Glockcubed's Avatar
Glockcubed
Thanks All. Some really good tips. i am rethinking some parts. Thanks.
QAfred
Milwaukee Eight (M8)
47
Feb 3, 2019 06:43 PM
Toby_2014
Oct 12, 2014 06:00 PM
Cyclenby
Sep 24, 2013 07:34 AM
1bagman
Mar 27, 2010 07:48 AM
2fas4u2
Jun 30, 2007 11:25 AM
