neutral to first clunk 'why'
Old May 9, 2012 | 05:45 PM
Nicky Pass's Avatar
Nicky Pass
That clunk is the chain tightening in the primary.
Even though this video is a "tad" biased, but it explains the noise at around 1:15 of the video....
http://www.youtube.com/watch?v=RGkFPUeNUqc
Old May 9, 2012 | 06:06 PM
Punjabi Rider's Avatar
Punjabi Rider
I think most Harley are design like that to let you know that the gear is engaged and you are ready to go.If you put in 1st when its cold it is loud most of the time and at the same time if you switch it into neural and go back to 1st again its very quiet because the clutch plates are not sticking as bad as before at cold start. Our 08 UC is very quiet most of the time but 07 UC is loud as its going to break both clutches are adjusted identical by me so clutch adjustment has nothing to do with it.
Old May 9, 2012 | 06:15 PM
2011 super glide dude's Avatar
When you pull in clutch oil in primary has clutch plates stuck together and when you move shifter and transmission gears engage it stops driven plates and there is your noise. If you pull clutch in and rev engine a few times it will loosen plates and sometimes won't make clunk or may not be as bad.
Old May 9, 2012 | 06:16 PM
editbrain's Avatar
editbrain
easy to remedy. pull the clutch, and roll the bike a little back or forward. should free it up some.
Old May 9, 2012 | 06:21 PM
FDHOG's Avatar
FDHOG
I like the looks I get from people when it clunks.
Every HD does it.
Old May 9, 2012 | 06:24 PM
Cigarmessenger's Avatar
Cigarmessenger
The clunk sound is cheaper than an idiot light on the dash. Hehehehe
racklefratz's Avatar
racklefratz
Originally Posted by GPHDXLC
The Search is not working.
So I got to ask, where dose the loud clunk shifting from neutral to first come from?.
Some more than others, yada, yada. C'mon. It's a Harley.
My Goldwing doesn't do that.....it's a Honda.
Get used to it, or buy a different bike.
Old May 9, 2012 | 06:31 PM
FDHOG's Avatar
FDHOG
That Victory video is interesting, but their bikes are still friggin ugly.
I'll keep my Hog.
Old May 9, 2012 | 06:37 PM
Guntoter's Avatar
Guntoter
The main reason a 6-speed clunks in any gear is because the mainshaft has 4 gears solidly mounted which create a lot of rolling momentum to stop when you shift into or through the gears.
I learned this on the Baker transmission website.
Old May 9, 2012 | 06:43 PM
RBWIDE's Avatar
RBWIDE
I'll keep my Hog.
Yep. Especially the 'Bozo' bike. What a visual monstrosity.
