132db Replacement Horn
Old May 17, 2012 | 02:39 PM
  #61
frog13's Avatar
frog13
Originally Posted by confused
So you guys really do use your horn?
Am I missing out? Will I get more HP?
I think I can say, that in all my motorcycle years, I have used my horn less than a half a dozen times. Yes, I ride in traffic, yes I have been cut off, better to react than blowing my horn at someone.
Good Luck with your new horns, seems like a good deal.
I bent the bracket on mine so the bottom of the horn is directed at the cylinders. When the engine gets hot, I hold down the horn button for about five minutes, the air from the horn blast cools the cylinders ......
Old May 17, 2012 | 02:57 PM
  #62
frenchbiker's Avatar
frenchbiker
Originally Posted by richie
Horn not worth it , not much louder than stock , if any . They must have measured that 132 decibels in an enclosed small space. Put my stock HD horn back on .
Are you serious? Mine make a BIG difference compared to the wimpy stock horn.
We're talking about 2 Freeway Blasters, hi and lo tone, right?
Old May 17, 2012 | 04:28 PM
  #63
1st 96 ultra's Avatar
1st 96 ultra
Originally Posted by HDV-GLIDE
I thought I was helping out with a cheap upgrade to the stock horn but again, I should have kept my mouth shut!!
If you can pick up a cheap self-contained air horn and mount it on your saddlebag bracket, that along with the Freeway Blaster should fill your needs. Total price with air horn, relay, wire, zip ties and the Blaster should be under $80.
That way you have a horn on both sides of your bike that will rattle your teeth when you push the horn button.
As far as total decibels, I'm a retired cop not an acoustical engineer, so I can only make assumptions and wild estimates. All I can say is, if the air horn puts out a claimed 139db and the Freeway Blaster puts out a claimed 132db, exactly what's the total output together of both horns???
oh it will be allright , not the first time I bought something I was nor real impressed with and darn suse not the most expensive , it is a little louder and I do have a spair now but I think Imight get the high tone now and you did not make us get them
Old May 17, 2012 | 05:18 PM
  #64
HarleyRanger's Avatar
HarleyRanger
Heres what I use....
Old May 18, 2012 | 08:38 AM
  #65
drukanfu's Avatar
drukanfu
I just replaced the stock horn with the freeway blaster, sounds identical to the stock horn. Well now I have a spare horn.
Old May 18, 2012 | 09:24 AM
  #66
vtwinbob's Avatar
vtwinbob
same here, glad it was only 10 bucks.
Old May 18, 2012 | 11:28 AM
  #67
Bocifus's Avatar
Bocifus
Yep, not much, if any louder than the stock horn.
Old May 19, 2012 | 08:54 AM
  #68
ripper43's Avatar
ripper43
Installed the horn this morning and without a doubt it is Much louder than stock... A really good $16.00 investment IMHO.
Thanks to the OP for the heads up.
Old May 19, 2012 | 09:14 AM
  #69
golfblues's Avatar
golfblues
DB's don't mean a thing unless you know how far the measurement was taken from. In this case they must've put the mic in the horn. lol
Btw, these horns were tested on this forum a few years ago. They were no louder then stock.
Old May 19, 2012 | 06:31 PM
  #70
racklefratz's Avatar
racklefratz
Originally Posted by capttxrngr
Bought one of these horns. Got it in today. Doesn't seem hardly any louder than the stock.
Ouch. WTF? You musta' gotta' dud, considering all the hoopla.
