what would redline be on a 103
Old May 13, 2012 | 07:24 AM
fistbump's Avatar
fistbump
Default what would redline be on a 103
thats the question, what would redline be on a 103, fistbump.
Old May 13, 2012 | 08:08 AM
ocezam's Avatar
ocezam
If I remember correctly it's something like 5600 stock and can be moved to 6200 with a new map. Why do you ask?
Old May 13, 2012 | 08:09 AM
Rooster37's Avatar
Rooster37
I do believe it is 5200...
Old May 13, 2012 | 08:13 AM
ppilotmike's Avatar
ppilotmike
1 RPM before self dissassembly begins.
Old May 13, 2012 | 08:34 AM
blusmbl's Avatar
blusmbl
Stock is 5800.
Old May 13, 2012 | 09:32 AM
ColoSpgsMark's Avatar
ColoSpgsMark
Most of the HD tuners will set 6200 as the limit. I'd suggest that as the high end, but factor in your cam as well. If you're running out of additional power after a given RPM, why push it that beyond that?
Old May 13, 2012 | 11:36 AM
skratch's Avatar
skratch
its the same as the 96. just cause its 7 ci bigger, it doesn't get a higher redline (unless changed by the tuner)
Old May 13, 2012 | 12:05 PM
mkguitar's Avatar
mkguitar
Over the past 25+ years ( evo and twincam), rev limiters have been set at 5200, 5500, 5600 etc. depending on which motor, which version of motor and the model bike it was going into.
For stock motors:
It is generally accepted that the valvetrain will tolerate up to occasional 6000 rpms.
After which valve float and the momentum of the moving parts can overcome the springs which control the valve action ( stronger springs would put more stresses on the valvetrain, causing slower action and more wear to the parts- reduced service life).
Being that torque is falling off above 4500 rpms, selecting the next gear is the better choice, than reving higher.
If in top gear, then wind it out and see how it does- for most baggers, wind resistance will be a factor before the rev limiter.
When setting my rev limiters I usually go at 5500 rpms- this saved my motor when my bike was hit and the throttle was jammed WOT while it lay on the ground.
Specially built motors, motors with cams will have other considerations
mike
myerted
The Dyno Room
Feb 15, 2017 02:40 PM
dynoflyer
Sep 5, 2014 09:39 PM
jefftc88
Dec 11, 2012 06:04 AM
dog116929
Apr 11, 2008 07:58 PM
snooper0069
Sep 9, 2007 06:54 PM
