Tightened the last bolt on my list of mods that started back in December. Since I ride year around I sequenced things out so it took a while. Adding to the delay was the leaking gas tank weld that had me without a bike for 4-5 weeks. A big thanks to HD corporate and Eastside HD in Bellevue for covering that replacement!
List of mods were as follows:
Wild 1 12.5" Apes (bars, lines, wiring)
HD LED Headlight
Boom Audio amp install
LED Gauge bulbs
GPS power supply wired in
Fairing mirror removal and PYO Bagga Chips installed
Ness RAD II Mirrors
Kury Seat Screw kit
All the labor was done by me. Now it is time to just ride.
This was the third set of Apes I had installed. Once you get over everything you have to pull off to do the job, it is pretty straight forward. The fairing and the ABS complicated matters a bit but not a bad job.
