Overheating !!
Old May 13, 2012 | 07:43 PM
Emonster6x's Avatar
Emonster6x
Default How do you take the Thermostst out?
Hey Guys, how do you remove the Thermostat on the HD oil cooler?
Old May 13, 2012 | 08:23 PM
dodger413's Avatar
dodger413
Default yes, i agree !
thanks....sumping sounds right.
BUT, where is all the oil going if it is? what is happening when it sumps? the oil is pumped into the top end, rocker boxes?? or stays in the cases? and this would be an OIL PUMP problem, then ??
also, if i turned the motor off for 10-30 minutes, wouldn't the oil return to normal, the oil pan?
the oil temp seems to get hot again very quickly after a restart.
not trying to be a pain in the ***, or beating a dead horse, but this really has me baffled.
thanks again for the help.
Old May 13, 2012 | 08:47 PM
WARDSPARTSWERKS's Avatar
WARDSPARTSWERKS
Sumping would indicate a pump issue. Your oil pump pulls and pushes in and out of the motor, if there is a problem like a bad Oring, alignment, or damage to the gearotor on the scavenge side, the oil doesn't get picked up properly from the bottom end so it doesn't get returned to the pan, the engine is a dry sump system meaning a segregated oil reservior, its not an oil bath bottom end, so if you have a sumping problem the flywheels are churning through oil that isn't supposed to be there, more load on the engine, less oil flow, less volume of oil circulating to share te burden of the heat it does carry away, and ultimately increased oil temperature. The oil will not drain back to the pan if you let it set, its not a gravity feed application.
Old May 13, 2012 | 08:55 PM
WARDSPARTSWERKS
Post #38 and #40 show the location of the thermostat and how to remove. Not sure what your motivation is, taking it out to benchtest is ok, but you can't just remove it and run without like you can in a car, its a different type of system, if you remove it oil will never flow to the cooler.
Old May 13, 2012 | 09:01 PM
Lowcountry Joe's Avatar
Lowcountry Joe
You need to verify the accuracy of the gauges that you have, both the oil temp and oil pressure. I think they may be more of the problem than anything else. Have you recently squirted them directly with water during a wash job? Just check their accuracy with some other instruments, don't condemn the operation of your bike until you perform this due diligence.
Old May 13, 2012 | 10:37 PM
Ride Ultra's Avatar
Ride Ultra
Not to hijack the thread but curious...when I'm tuning my PCV, it shows engine temp. Is this the cylinder head or oil temp?
09 UC was running a bit hot (I think) so did a test this weekend by letting the bike sit idle as if in traffic to test the engine temp. Yes, I know the manual says not to let our bikes idle but this test was less than what I experienced in a traffic jam earlier this week. After a few minutes it creeped to over 300. Was only 72 degrees with light wind, not nearly the conditions we would find in traffic. While still idling, forced air on the cylinder heads (electric yard blower) for about 2 minutes and no significant decrease in temp.
I see the good/optimal operating temps for the oil but do the heads run hotter? Should they run that much hotter?
Update: Never mind, just read the "Werks" site and see the heads do run much hotter. My head temps at idle were around 240 for the first few minutes so I should be good.
Old May 13, 2012 | 10:49 PM
Lonewolf176's Avatar
Lonewolf176
Cylinder head. The sensor is on the back left side of the front head. The heads will run hotter. Temp at the spark plug is even higher ( approx 70-80 degrees). The front cylinder will run hotter while stationary as it works harder because the firing order is not 360 degrees apart. Once moving the rear is hotter due to air flow. A pair of 1 1/2 hp fans on the dyno even takes a couple of minutes to reduce the temps.
Bart van der Meulen
2014-2024 Touring Models
16
Aug 13, 2015 05:48 AM
geargrinder
Sep 15, 2014 06:45 PM
MULESKINNER
11
May 8, 2008 05:17 AM
Booey424
May 7, 2007 02:58 AM
texas725
Mar 24, 2007 11:45 AM
