installed adj backrest today...
Old Jan 5, 2007 | 04:54 PM
2CMan's Avatar
2CMan
Default RE: installed adj backrest today...
looking at the pic of your road glide, the backrest look like it fits right down on top of the top of the seat, no gap between the bottom of the backrest pad and the seat top.
On mine, there is a gap of about 3 inches, as if I had the pad adjusted in one of the upper height positions. Maybe I've got a defective backrest....
Old Jan 5, 2007 | 05:32 PM
Vegas FLTRI's Avatar
Vegas FLTRI
there is a button in the middle of the back that alows the pad to move up and down there are 5 postions I beleive, check and make sure yours is in the lowest position.
Old Jan 5, 2007 | 05:46 PM
2CMan's Avatar
2CMan
I'll give that a try. I've only found three positions on my pad, but will play with it tonight. Thanks for the help. That RoadGlide looks awsome with the lowers, very sharp ride !
Old Jan 5, 2007 | 06:07 PM
Xtreme Hawg's Avatar
Xtreme Hawg
Your going to love the backrest !!! It makes long rides more enjoyable, the only downfall is not feeling mama up close and personal.
Old Jan 5, 2007 | 06:53 PM
oley55's Avatar
oley55
my manual adjustable H-D seat (without hrdraulic piston) has four mounting positions to the rear fender/frame (front to back). then there are four height adjustments (up and down),then there is the set screw backrest tilt adjustment.
if needed I can pull the seat and take pictures of the backrest adjusting/mounting options.
Old Jan 5, 2007 | 08:02 PM
Vegas FLTRI
ORIGINAL: 2CMan
Thank you good luck, And Hawg I remove the backrest when Mama comes along for that very reason.
Old Jan 5, 2007 | 09:03 PM
iclick's Avatar
iclick
ORIGINAL: The HalfBreed
On long rides, a backrest is wonderful.
On long rides, a backrest is essential.
Old Jan 5, 2007 | 09:10 PM
halhogan's Avatar
halhogan
Those who have never used a backrest, do not realize what a difference it will make, especially on long rides.
Old Jan 8, 2007 | 10:49 PM
voodoodrug's Avatar
voodoodrug
well test road the backrest and HALHOGAN said it well. Did not realize how much pressure was relieved off back. Only one note though, at first had backrest set to lowest(vertical adj). This pushed the back rest cushion down on the seat and caused a small bulge at back(lumbar) section of seat,which did push me forward a little when just cruising around. Fixed this by moving vertical adjustment to 1st or 2nd vertical position. All I can say is awsome!
ps sorry no pix (lazy) but its on hd web. -->backrest-comfert stitch adj backrest. msrp 297 around 240 online dealers.
Old Jan 9, 2007 | 12:14 AM
MCSarge's Avatar
MCSarge
My RK Classic came with the backrests when I bought it used. I spent last weekend taking the narcelle off so I could adjust the handlebars back so I could reach the backrest. My brother, who I got the bike from is 6'4" and the bars were so far forward I was leaning away from the back rest. But all is good and comfy now. I made sure to have the rest on when I was adjusting the bars. Took almost 3 hours to take everything off and put it back on to make a 5 minute adjustment.
Ranger Rick
Mar 18, 2018 09:58 PM
NewAge
Jan 15, 2012 01:43 PM
CFDgrunt
Aug 13, 2008 06:12 PM
tmoreau
Feb 19, 2008 07:07 PM
