Prevent an oil leak
Old Aug 30, 2012 | 07:54 PM
mike5380's Avatar
mike5380
Yep, that exhaust bracket bolts onto the bottom of the side door. I took my exhaust completely off to get access to all bolts on the side door, removed and cleaned each bolt, dotted them with blue loctite and retorqued to 25ft-lbs. No more leak. Took me about two hours, but a Harley tech will probably charge 4 to do the same job.
Mike
Old Aug 30, 2012 | 10:28 PM
Deuuuce's Avatar
Deuuuce
No charge from San Jose HD!
Old Aug 30, 2012 | 10:32 PM
glcash's Avatar
glcash
Mines leaked there. Put locktite on them. Problem solved.
Old Aug 30, 2012 | 10:44 PM
NECaveman's Avatar
NECaveman
I had this leak on my 2009 SG last winter in storage. On mine the problem was a deteriorated gasket between the transmission housing and bearing housing on the right side for on the exhaust bracket bolts.
https://www.hdforums.com/forum/touri...stay-gone.html
Old Aug 30, 2012 | 11:39 PM
DannyZ71's Avatar
DannyZ71
I actually lost one of the bolts. Don't know how it didn't leak. The front one stayed tight, but the dealership pulled it also and put lock-tite on both it and the new one. No problems since then.
This is good advise to anyone just getting one of the new bikes. Check and lock-tite those bolts!
Steven A Cross
Jul 18, 2018 12:53 PM
ronherman
Sep 3, 2013 07:31 PM
lostrider06
Oct 24, 2011 06:51 PM
al baehr
Aug 30, 2010 08:13 PM
ekcivic1
Feb 26, 2009 12:45 PM
