I don't think your AFR is too rich as was suggested earlier, and once you hit 3500 RPM it levels off at about 13:1 which is good. Thus, I don't think your tune is the source of the high-end power loss, although I would want the AFRs to remain at ~13:1 at WOT throughout the RPM range. If the fuel pressure was the issue I would think it would show up on that chart.
What comes to mind that I don't think has already been mentioned is sumping. Does the bike run hot? Just to eliminate this as a possibility, warm the bike thoroughly and remove the engine-block drain plug (under the crank, not the oil pan). You should drain 6-8 oz. of oil, and I would make this easy check before contemplating more invasive diagnostics.
Sumping here too. Is the TB blade opening fully at WOT?
Thanks for the comments, but yes I have checked for sumping, got a whole 2 oz. when the plug was pulled. As for the throttle plate, I have watched it and it looks to me like it is opening completely and the computer says it is on the TMax monitoring. And Iclick, this is about the coolest running engine I have ever seen. Even in this Az. heat it takes it 7 or 8 miles to get above 170 F. of oil temp. If the ambient is below 70 F it won't exceed 170 F oil temp in the 15 mile trip to work.
Just for an update, had the fuel pressure checked today and it is at 58 psi, dead in the middle of the range. The tech said the bleed down was good also. Again I'm at a loss. Not sure what to do now. I don't know if changing the throttle body and injectors would do anything, it's about the only thing I haven't done yet. I ran a hot compression check last night, 205 psi on both cylinders. It holds 193 or 194 when it is cold. I haven't done a leak down, but with that kind of compression I don't think a leak down will show a problem.
Thanks for the comments, but yes I have checked for sumping....
Okay, that eliminates that. Do you have the concentric or standard baffles on those D&D mufflers? I've been told by a knowledgeable source that if the former this may be your problem, as they are too restrictive for the 107.
This is the D&D 2:1 Boss system. I don't know that they offer more than one baffle for it. A restrictive baffle should increase the torque & restrict the HP somewhat.
Try different cams?
I have thought about that. I bought these TR590's off the forum, so they weren't new. I know now (I didn't then) that Tman had a bad run on the cams, but according to him is was only a noise problem and had no affect on performance. If I changed cams I would consider the Head Quarters TC 600 HC. I would be interested in hearing about experiences with this cam.
I would go with another cam beside HQ. I'm just say'n.
Ok Now with a compression check at 205 we know the motor is internally good and there is no sumping.
I would throw that tmax in a garbage can and get a tts tuner.
I would stay away from hq cams they build way too much cylinder pressure.The result is having to cut a ton a timing to stop the pinging.
Check to see what baffle you have? The concentric baffle is closed off and the wraped one is open.
