I'm not hitting the rev limiter in 5th or 6th. stock windshield and the only wind deflector I have is the one that goes between the forks on the back side of the lower tpiple tree.
Does your buddy have the same exact bike, with the same add ons? Do you both weigh the same?
No his is RGU mine is a EGC his is stockexcept for cam, exhaust, and tuner, making 104tq 93hp Mine has cams, heads, pistons, exhaust, tuner, 111tq 110hp.
Sounds like his is tuned more for upper end of rpm range while yours is better at lower rpm. You're probably hitting peak torque lower down in the rpm range than he is. Peak HP may be irrelevant if you can't get to the rpm and vehicle speed due to wind resistance.
Does it feel as if it's starved for fuel? It may be something as simple as your fuel filter needing changed. If you had it on a chassis dyno, did it pull through the 110 MPH barrier? Or did it hit the wall and stop pulling?
