Adding lowers to SG. How does it affect engine temp?
Old May 22, 2012 | 10:21 PM
trosel238's Avatar
trosel238
Default Adding lowers to SG. How does it affect engine temp?
I've been thinking of adding Vented Lowers to my 2010 SG. If I do this, what effect will this have on engine operating temperature? I'm sure the airflow will be a little different, so it might effect engine temp. Just wondering what your experiences have been
Old May 22, 2012 | 10:41 PM
mkguitar's Avatar
mkguitar
fairing lowers will lower oil temp measured at the pan about 25ş with ambient temps at 105ş. ( no oil cooler on the bike)
I've written a couple of times on the testing I did
mike
Old May 22, 2012 | 11:30 PM
Mntsnow's Avatar
Mntsnow
Yep the lowers actually help cool the motor as it channels more air into and across the motor. The potential downside is there maybe more warm/hot air being felt by the rider. This is great during the cold weather but can be nuisance during the hot summer
Old May 23, 2012 | 01:24 AM
bmb's Avatar
bmb
I have never thought to pit my heat gun to the test on that. However as far as add'n lowers. I did. I love them. I will never take them off,or have another SG with out them. I must say if if u leave out on a cool am with them closed and come warm up u forget to at least crack'm open 1/2 way ur feet will be sweat'n in ur boots. I run mine closed if its under 60 degrees. Soon as it hits mid 60s + u better start open'n them.
Old May 23, 2012 | 07:53 AM
trosel238's Avatar
trosel238
I like the idea of the cooler oil temp, but I am a little worried about extra heat on the rider. It gets awful hot in West TN during the summer.
Old May 23, 2012 | 08:07 AM
3/4 life crisis's Avatar
3/4 life crisis
I use Hogg Chopps instead of OEM lowers. Not a problem, both engine and my legs. I was told if you retain the football A/C cover, your legs will be cooler than open element covers.
Old May 23, 2012 | 08:38 AM
hd_rolling's Avatar
hd_rolling
I feel a lot more heat on my legs compaired to not having lowers on. This is my first season having them and I had to check all my fluid levels thinking something was wrong. Removed the lowers and the issue was solved. I still leave them on most of the time to help with buffering and a little more storage.
Old May 23, 2012 | 05:50 PM
trosel238's Avatar
trosel238
The heat issue in the summer is what concerns me, but for long trips I like the idea of less wind buffeting. With the quick detach ow easy are they to take off and reinstall?
Old May 23, 2012 | 08:03 PM
Mntsnow's Avatar
Mntsnow
I can take mine on and off in about 20 minutes for both sides
Old May 23, 2012 | 08:09 PM
HFS's Avatar
HFS
Huh. I have the soft lowers and is says in the instructions to remove them if the temp is >70F. (by memory.) the lowers must direct air and cool motor.
I didn't consider them with the 120r and potential heat issues.
Good to know.
(and another part to lust after... Crap)
Harry
