Syn or not to syn?
Old May 25, 2012 | 07:42 AM
lionsm13's Avatar
lionsm13
Originally Posted by DK Custom
I too have had much better experience with Formula plus in my primary. Trans and engine get full synthetic.
Same Here.
Old May 25, 2012 | 08:01 AM
Max96's Avatar
Max96
My bike always has Formula+ in the primary, never had any problems.
Old May 25, 2012 | 09:00 AM
mike_oh's Avatar
mike_oh
Barnett recommends ATF or B&M Trick Shift with their clutches.....
Old May 25, 2012 | 09:12 AM
Steve On 3's Avatar
Steve On 3
How frequent are you changing the primary with formula??
My evo i changed it every other oil change which was 5 k miles. Took my 12 limited in and told the dealer formula in the primary and he said it would need to be changed at 2500 miles. Wtf? Told him my evo had 168k miles on it, running formula. Put new clutch in at 125k just because i wanted no problems. So when do you change primary if using formula? Sorry to hijack the thread
Old May 25, 2012 | 09:36 AM
Leftcoaster's Avatar
Leftcoaster
Originally Posted by Shredding rubber
I've heard of guys using ATF in the primary but I know some atf's contain friction modifiers,which will ruin the clutch.
Does anyone know which atf's have friction modifiers and which don't.
I'm sticking with rotella. All the fluids I use are easily found on the road or a parts store.
Except for shockproof but I would have no issue running any gear oil in my tranny.
Your results may vary
ATF's are pretty much all the same nowadays. Been using it in my primaries for hundreds of thousands of miles and many years on more than a few HD's with zero problems. The stuff is cheap, always available and designed for everything the primary does. No compensator troubles either .
The HD stuff works just as well but costs more and you can only get it at HD. Naturally, if you buy ahead you won't have a problem but should you forget just go down to your local Oh! Oh! Oh! O'Reilly's and pick up some ATF and forget about it.
I've never run a motor oil in a primary but would do so in a pinch - sometimes you gotta' do what you gotta' do to get yourself back home.
I change the primary every service (5K mi).
Old May 25, 2012 | 09:46 AM
FenderGuy53's Avatar
FenderGuy53
Formula + in the Primary and Trans
HD 20W50 in the Engine
Old May 26, 2012 | 12:41 AM
oldschoolhd's Avatar
oldschoolhd
2nd Gear
Does any one use Red Line in there Trans?
SG-Jay
Mar 3, 2020 04:26 PM
South107
Milwaukee Eight (M8)
14
Apr 16, 2019 12:31 PM
smokingjoe
22
Aug 10, 2017 07:21 PM
backdoc_rider
Oct 7, 2009 12:02 PM
Edmo
Sep 9, 2006 04:10 PM
