Syn or not to syn?
Old May 24, 2012 | 11:52 PM
oldschoolhd's Avatar
oldschoolhd
2nd Gear
Default Syn or not to syn?
I thought I would share some personal experience with everyone.
I bought my '08 flht new in June of '08, and put 1000 miles on it the first weekend. At my 1k service I chose to run Syn3 in all 3 boxes. I'm a H-D tech and $ wasn't a concern being I could get fliuds for free. After a very short time I started to notice that my clutch felt "wrong". Every time I left from a stop it looked like I had never riden before. I adjusted the clutch, replaced the cable. I was tottly stumped. So, after 12,500 miles I switched to Formula plus in my trans and primary. AND low'N behold after about 45 miles the clutch was like brand new. And has been awsome ever sence (29,400)
Now the reason I switched was due to an issue we were having with police bikes. They were haveing clutch failures often and in low miles, and when we contacted H-D they siad to try switching out the primairy fluid. Said it was to slippery.
Just thought I would share that, hope it helps some one.
Old May 24, 2012 | 11:56 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
I too have had much better experience with Formula plus in my primary. Trans and engine get full synthetic.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old May 25, 2012 | 06:30 AM
scj's Avatar
scj
I use automatic transmission fluid in the primary. Used it since the '90's and have never had a clutch failure even with my 125+ hp '08 113" SG.
Old May 25, 2012 | 07:00 AM
Rickr01's Avatar
Rickr01
Formula + in the Primary, Amsoil 20/50 in the motor and Amsoil 75/140 in the Tranny. Smooth as Butter!
Old May 25, 2012 | 07:05 AM
RBWIDE's Avatar
RBWIDE
Old May 25, 2012 | 07:08 AM
Shredding rubber's Avatar
Shredding rubber
I've read many threads where guys have had issues with a syn fluid in the primary.
I use rotella 15w-40 diesel oil in mine and have never had an issue on my Harley and I've used rotella faithfully in my jap bikes and never had an issue with them either.
The primary doesn't need any of that expensive stuff.
Old May 25, 2012 | 07:13 AM
Ronp42's Avatar
Ronp42
Account Retired
I agree with the Rotella-T 15/40 or Formula+ in the Primary. I don't agree with using ATF. I don't think it's enough protection for the Compensator. JMO
Mobile 1 15/50 Engine
Rotella-T 15/40 Primary
Redline V-twin in Tranny
Old May 25, 2012 | 07:14 AM
aviscomi's Avatar
aviscomi
Some clutch manufacturers (Rivera) recommend agains syn in the primary. I run Formula+ in my 120R due to the high torque.
Old May 25, 2012 | 07:22 AM
bigskyroadglide's Avatar
bigskyroadglide
+1 on formula plus, or in a pinch any good quality oil such as rotella in the primary.
As to the tranny, bel ray 85/140 instead of Syn.
My independent repair shop, has been replacing tranny bearings on a bunch of 07's due to bearing failure, most of them with Syn in the tranny.
Engine, gets Syn, why? Tried most of the others, engine seems quieter with Syn, its readily available on the road if needed and its not an easter egg hunt to find if I need to find it.
Old May 25, 2012 | 07:28 AM
Shredding rubber
I've heard of guys using ATF in the primary but I know some atf's contain friction modifiers,which will ruin the clutch.
Does anyone know which atf's have friction modifiers and which don't.
I'm sticking with rotella. All the fluids I use are easily found on the road or a parts store.
Except for shockproof but I would have no issue running any gear oil in my tranny.
Your results may vary
