Directions
Old May 25, 2012 | 10:29 PM
2001NightTrain's Avatar
2001NightTrain
Write abbreviated directions on a small piece of paper and tape it to your dash or windshield using blue painters tape. Sticks strong enough to hold without damaging the surface. Works great
Old May 25, 2012 | 11:03 PM
Wardenbf's Avatar
Wardenbf
Originally Posted by baust55
I use a $4 atlas ,i put the way points for the next cpl hundred miles in my brain and go .
If i forget i stop and look at the map again . i am CHEAP ! eeeeeeerrr ! i mean THRIFTY ! '
I am getting old i might need a new system if the memory goes . ha
I believe the word you're looking for is "Frugal". I should know because every time my wife calls me a "cheap bastard", I have to remind her of the correct term.
Old May 25, 2012 | 11:08 PM
spizzyman's Avatar
spizzyman
Originally Posted by Black_Hog
Why don't you get a low priced Garmin GPS and a RAM mount set. It's worth it's weight in gold on the road.
I use a Garmin 360 with a RAM mount and a plastic bag/rubber band for rain protection.
That ain't right. Don't you know you are supposed to spend over $600.00, so you don't have to use the plastic bag?
spiz
Old May 25, 2012 | 11:15 PM
bruce sg08's Avatar
bruce sg08
A t bag magnetic map case. I write or print out directions cut to size, and laminate the sheets so its water proof. Use one card for each day, any changes use grease pencil on laminate sheet. On the tank I cut and fit window film tint so it doesn't mark up the gas tank. Peel and pitch when done doesn't leave any residue. Only use this method for trips but works good. Here is a copy of one of the sheets I laminated.
TURNPIKE TO BREEZEWOOD EXIT 161 95 MI
BREEZEWOOD EXIT TO I 70 e
I 70 e to 522 s 24 MI
522s to 37s (towards Hancock/Winchester) 40 MI
37s to 81s (towards Roanoke) 10 Mi
81s to 66 e (towards Front Royal/ Washington) 10Mi
66 e to 340 s ( into Front Royal ) 15Mi
I highlight the route numbers so its easier to follow. and the mileage gives me an idea where I'm at and when the turn is coming up.
Old May 25, 2012 | 11:50 PM
byersmtrco's Avatar
byersmtrco
Remember paper maps?
Look at the map . . .
Still easier than listening to Paula
(my name for my garmin GPS)
Recalculate THIS !! Bitch!!!
Old May 26, 2012 | 02:56 AM
jackstrr's Avatar
jackstrr
yuuuup, a map. or what the hell ...why not try and get lost. I try and get lost every year for something new and differant. Always seem to find home again sooner or later.
Old May 26, 2012 | 02:57 AM
doctorharrison's Avatar
doctorharrison
Post-It Notes make some types that 1). Have adhesive (still removable though) over entire back surface instead of just one edge; 2) have a slightly more aggressive backing. Work like a charm - just stick one of them on your tank or riser cover and you're good to go
Old May 26, 2012 | 03:04 AM
103 sedona orange's Avatar
103 sedona orange
RamMount & Garmin Nuvi 1300
Old May 26, 2012 | 07:30 AM
NoDeal's Avatar
NoDeal
TBag magnetic map case. Cheap and easily viewable window to put in directions or maps. I used this for lots of rides, including multiple IBA rides and it never failed, fell off, scratched the paint etc. the only issue was that, while rain would not penetrate too much, a little water may get into the map case. On a hot day that turns to steam, which fogs the window and dampens your papers. Only happened to me a couple times, wipe off once and no recurrence so not a big deal.
I hate GPS, ridden with several guys when their gps garbage. had us running in circles, disregarding common sense or lines on a map. Never again.
Old May 26, 2012 | 07:36 AM
gonzo3426's Avatar
gonzo3426
here's suggestion:
- google map your trip, make some mental notes
- head in the general direction you're going...i found the hard way, to stop for gas around 200 miles...my low fuel light gauge stopped working...
- when you stop for gas, think about the mental notes you took or ask for directions...
- keep ridin'
