heat wrap the cat
Old May 26, 2012 | 07:36 AM
papejr's Avatar
papejr
Default heat wrap the cat
Has anyone put heat wrapp on the cat to reduce heat? Does it harm the motor to do this? Thanks
Old May 26, 2012 | 07:43 AM
WARDSPARTSWERKS's Avatar
WARDSPARTSWERKS
It will knock down some heat, and it wont harm your motor, but wrap has the potential to accelerate oxidation/deterioration of the base metal of the pipe, by attracting and absorbing moisture and retaining more heat.
Old May 26, 2012 | 09:25 AM
lionsm13's Avatar
lionsm13
Why not just cut the cat out?
Old May 26, 2012 | 12:18 PM
Gearhead3's Avatar
Gearhead3
Is there room to place a fabricated heat sheild around it?? Does anyone even make one?
Old May 26, 2012 | 01:13 PM
drewski1325's Avatar
drewski1325
I put heat wrap on a Martin Bros pipe I had on my softail as there were no heat shields for the pipes. I really didn't notice much of a difference but it looked cool.
Old May 26, 2012 | 01:59 PM
Harleydaddy's Avatar
Harleydaddy
Just gut the cat and be done with it! You will notice a much cooler engine and it'll sound a little better too. You will thank me later when your out there on a hot day and your not roasting from all the heat your engine is throwing cuz of that damn cat!
Old May 26, 2012 | 02:04 PM
dan conner's Avatar
dan conner
cut out the cat and add xied's. this is a cheap and easy solution that works well.
oricko
Aug 7, 2013 09:35 PM
olsenjb
Jun 20, 2012 07:20 AM
masterblaster
Mar 30, 2012 12:50 PM
randytro
May 13, 2010 06:21 PM
SPECIAL ED
Sep 15, 2006 03:18 PM
