Power Vision Speedo Re-calibration
Old Feb 28, 2016 | 04:09 PM
  #51
InTheWinda1's Avatar
InTheWinda1
Default hd brain
Originally Posted by Tx_Rider
I know this an old thread but still relevant.
Trying to calibrate my speedo/odo
PV and speedo/odo are off, and I dont think they should be, they use the same data.
Speed is off by 0.61%
But odo is off by 0.78%
On a recent ride my PV trip center mileage did not match the odo mileage.
Am I missing something? I am using the quick tune to change the vss parameters
Thanks
The HD brain , tells Power vision the speed , so should B about about the same --PV cannot figure speed out , has to use what comes from HD brain,,,-- GPS on phone takes in 7 to 14 SATS , is very accurate . I use Speed View Pro 2 or 3 bucks . Does a lot of stuff , 1/4 mile distance and on and on .Power vision has great support .
JIM
JIM
Old Oct 2, 2016 | 04:17 AM
  #52
bodgie1307's Avatar
bodgie1307
Question
I want to recab my 2014 breakout speedo after a pulley change and a mate has a PV for his Rocker
Can i use his PV or will i require a second liscense ?
i have a SESTP
Old Oct 2, 2016 | 05:07 AM
  #53
Bone Doc's Avatar
Bone Doc
Originally Posted by bodgie1307
Question
i have a SESTP
It will require a second license. The Power Vision is married to the first vehicle it is used on.
Old Oct 3, 2016 | 07:12 AM
  #54
patrick74's Avatar
patrick74
You can also do it just from the PV. Goto Quick Tune, once there goto the config tab. You will see a box marked VSS. Make note of that number and make and save your changes. Remember if you reflash from the stores tunes and you did not modify it in the tune it will over right that number
Old Oct 3, 2016 | 08:27 AM
  #55
PoCoBob's Avatar
PoCoBob
Originally Posted by josame
Can you calibrate the speedo in QUICK TUNE-CONFIG tab on the Power Vision its self by changing the value in the VSS box?
Yes, you can do this with the unit attached to the bike in Quick Tune.
There was a thread a few months ago with the guys who have FP3's and theirs will auto adjust based on the GPS in their phones. From what they were saying somewhere between 2235 - 2245 pulses is correct for a stock bagger with a 180 rear tire. Mines set at 2233 and I think that came from a map I got from Fuel Moto.
Old Oct 3, 2016 | 08:56 PM
  #56
ejwmiller's Avatar
ejwmiller
You don't have to use the pc to do it. You can change the vss directly from the power vision. It's I the quick tune section. Very easy to do.
Sorry didn't read the whole thread.
Old Jul 26, 2017 | 10:17 AM
  #57
mrlexus's Avatar
mrlexus
On a Rushmore model with the GPS, is the speed displayed on the screen linked to the vehicle speed sensor, or is it actual GPS speed? My screen and speedometer are slightly off. I use the number on the screen more often, and it is accurate, but I will adjust the speedometer with the Power Vision if they aren't linked...
Old Jul 26, 2017 | 11:12 AM
  #58
ke5rbd's Avatar
ke5rbd
My guess is they are separate as lot of models don't have GPS and their speedometers work. Too simple to have GPS display its own speed and not use the ecm to supply. My guess.
If you have PV you can change the PV speedometer calibration about 100 points more and the speedometer should read about 3 mph faster. Then compare and see if different.
Old Jul 26, 2017 | 11:23 AM
  #59
SBates08's Avatar
SBates08
Hey Mac. Where have you been brother? Haven't seen you on here in quite some time.
Old Jul 27, 2017 | 06:40 AM
  #60
mrlexus's Avatar
mrlexus
I verified the speedo and GPS speed are not linked. I was able to adjust my speedometer the 1.5 MPH at 60 to make them read the same. Verified with phone GPS also.
samhallnc
Aug 6, 2018 08:39 AM
av8or
2014-2024 Touring Models
20
May 30, 2016 04:29 PM
Rich67
Jun 16, 2014 01:14 AM
djl
Exhaust System Topics
Dec 1, 2012 02:00 PM
Shovels4ever
Shovelhead
Oct 27, 2007 02:03 PM
