Exhaust question
Old May 28, 2012 | 07:57 PM
gdbice's Avatar
gdbice
Default Exhaust question
I know this question has been asked before. I was trying to look in some section that had older questions so not to waste anyone's time, but here you go. I have a completly stock 2010 Ultra Limited. I'm just looking for a good set of slip ons. I don't want to do a Stage 1 upgrade, big air kit, or programer. I just want a little deeper sound but still enjoy my music. Thanks for reading.
Old May 28, 2012 | 08:03 PM
madhunter60's Avatar
madhunter60
fuelmoto 4" dyno tuned mufflers
Old May 28, 2012 | 08:05 PM
zoozoo's Avatar
zoozoo
Take the CAT out of the pipe. You lose the heat and get a little rumble to boot.
Old May 28, 2012 | 08:07 PM
gdbice's Avatar
gdbice
Will taking out the CAT's effect anything with the computer?
Old May 29, 2012 | 04:38 PM
mllgator's Avatar
mllgator
Try the "American Custom" website. They will modify your existing pipes or send you a set; you then send them back your originals and get the core charge refunded to your card. Very inexpensive!
You really should consider a Stage 1 though, after all it is only a free-er flowing air cleaner, mfg by H/D so there are no warranty issues. A re-map (and there are a ton of opinions out there on this issue) is only about $150 and your bike (and warranty) are running spot-on...
Think of it this way: more air in, more air out, a simple recalibration to your ECM and the bike is running the way they all would - if not for California and NY polution control regs.
Old May 29, 2012 | 04:41 PM
Ghostman574's Avatar
Ghostman574
+1 They sound awesome.
Old May 29, 2012 | 04:52 PM
qtrracer's Avatar
qtrracer
I would do a disc type muffler if you want to be able to hear your music. The thing is what you think is loud might be quiet to someone else or vice versa, and the disc systems allow you adjust the tone to suit you. SE or Supertrapp would work well.
Old May 29, 2012 | 06:47 PM
zoozoo's Avatar
zoozoo
Changing mufflers only NO. If you do a Stage I and mufflers YES you will have to reflash ECM.
Old May 29, 2012 | 09:01 PM
RK Joy's Avatar
RK Joy
If you are looking for just a "little more" thunder so you can still enjoy the music you might look at the SE slip-ons. Supposedly they add just +2db to the sound level. (According to *MY* dealer's parts expert.)
Old May 29, 2012 | 09:34 PM
DeneFXDWG's Avatar
DeneFXDWG
Absolutely
stevil66
Apr 7, 2015 08:18 PM
DonCMcC
2014-2024 Touring Models
17
Mar 16, 2015 07:34 PM
bkgabby
Sep 21, 2013 07:52 PM
nivensid
Feb 4, 2013 07:41 PM
gibbyair
Aug 13, 2007 10:35 PM
