Fiction zone
Old May 29, 2012 | 08:43 AM
Chopperbob's Avatar
Chopperbob
Default Fiction zone
I recently had some clutch work done and I want to move the release point closer to the grip I have adjusted the basket but it never seems to change the release point
Old May 29, 2012 | 09:18 AM
TUCCI's Avatar
TUCCI
Ive tried playing with the adjustment to adjust the friction zone
and it never really moves it anywhere. I think the important thing is to make sure there freeplay before the clutch engages or it will be partially engaged and thats not good.
Old May 29, 2012 | 09:57 AM
Big Trev's Avatar
Big Trev
Smile
There's a right way and a wrong to adjust the clutch,follow the W/S manual get it wrong, and you'll be coming back on here saying your clutch is dragging and you can't get the bike into gear
Old May 29, 2012 | 09:59 AM
rdunn22's Avatar
rdunn22
Just like Big Trev said (Right and Wrong way). The problem is if you adjust the clutch the way you want it, it will most likely not be disengaging enough, putting additional stress on the transmission.
I don't like to have my clutch setup like that, but I think the best way to do it is by making the adjustment at the cable. The adjustment at the Clutch Basket is less forgiving.
Make sure the Basket is adjusted right, and then just loosen the cable adjustment to where you like the lever to operate; making sure the clutch is adjusted to allow proper engagement/disengagement
Old May 29, 2012 | 10:56 AM
mkguitar's Avatar
mkguitar
the late model ball and ramp lever uses just about all the area of the clutch lever travel- this makes for less left hand effort.
the earlier ramp used a shorter lever, so more effort in less space- this better allowed the "working area" of the clutch lever to be moved closer or further from the grip.
The ball/ramp is less than $20 in parts. I do not now if the earlier version will fit into the current trap door
typical assembly looks likes the below linked diagram, the inner ramp ( #17) attaches to the clutch cable with the arm, the longer the arm the more clutch lever travel/less effort
http://partsfinder.onlinemicrofiche....W/-SIDE-COVERS
Having had earlier models; a popular mod was the white brothers easy boy lite clutch kit, which is essentially what HD offers now. The earlier clutch could make for a sore hand in a full day of city riding- esp with a performance clutch/spring
A clutch adjusted per the service manual will give good "friction zone" results, just pay extra attention to the clutch cable adjustment, and the gap at the lever
Mike
Old May 30, 2012 | 12:24 PM
vistavette's Avatar
vistavette
I found the following when adjusting my clutch:
Loosen the cable all the way -
Loosen the lock nut and the center screw then when backing it out to lock it in:
For a mid-way turn back the adjuster out on the basket about 1/2 turn.
Closer to the grip 3/4 to one full turn.
Personally I always use 1/2 turn as it puts the friction zone just about half way out; gives you plenty of play area when needed and makes for very smooth take off or slow speed parking lot clutch feathering. When its too close to the grip it gets grabby (IMO). If that's your preference then the 3/4 to 1 full turn out will accomplish that.
Old May 30, 2012 | 04:47 PM
longrideshields-1's Avatar
longrideshields-1
Premium Sponsor
same here. just on a side note, the title of this thread had me ready to discuss my favorite Stephen King book....
__________________
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
Old May 30, 2012 | 05:24 PM
2black1s's Avatar
2black1s
This is really quite simple. More freeplay will make the clutch engage closer to the grip. So to accomplish that, simply adjust the clutch (inside the cover) to the high side of the tolerance range, i.e., one full turn rather than 1/2 turn. If that alone does not accomplish what you're looking for then give the cable some extra freeplay. Disregard the 1/16 to 1/8 inch specifaication at the clutch lever and adjust the cable to provide the engagement where you want it. If your bike is anything like mine you'll end up with more than 1/8 inch freeplay at the lever.
In another thread on the same topic I proposed this method in more detail. I got a reply stating that my methods were about the stupidest way of adjustment conceivable. I asked the poster who stated that to provide me with a technical rational for his statement but never got one. The reason for no follow-up response is because there isn't one. My method is perfectly sound and will result in a clutch engagement to suit your preference.
Old May 30, 2012 | 06:28 PM
VTGlideRider's Avatar
VTGlideRider
Heck I thought it was a thread about an HD dealer giving something away for free
Old May 30, 2012 | 07:51 PM
jberg's Avatar
jberg
I also expected a pun. It really is a good title for a humorous thread.
