Tranny EPIC fail
Old Jun 1, 2012 | 05:37 PM
Tortoise98's Avatar
Tortoise98
Angry Tranny EPIC fail
My '09 UC started making an intermitant noise from the tranny. Since I have ESP, I took it to the dealer. Tranny full of metal shavings. They pulled the gear set out and you can see where things are making contact, but no sign of root cause. They are replacing it, but I an growing tired of all the failures on this bike. Only 54,000 miles, too many issues. Now I am on vacation with no bike.
Thanks for the opportunity to vent.
Old Jun 1, 2012 | 06:48 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Rent one!
Old Jun 1, 2012 | 06:52 PM
Guntoter's Avatar
Guntoter
They need to pull the main drive gear bearing as that is most likely the cause. Lots of failures with those.
Old Jun 1, 2012 | 06:57 PM
09FLHT's Avatar
09FLHT
Short vent. Let us know what happens.
Old Jun 1, 2012 | 06:59 PM
bigskyroadglide's Avatar
bigskyroadglide
+1 on main drive gear bearing. lots of problems with those showing up
Old Jun 1, 2012 | 07:22 PM
vaham's Avatar
vaham
Makes me wonder if these main drive gear failures are in some way related to the automatic primary tensioner.
Old Jun 1, 2012 | 11:14 PM
skratch's Avatar
skratch
curious as to the list of failures. so far, i've not had any (knock on wood)
Old Jun 2, 2012 | 12:06 AM
Loc_Tite's Avatar
Loc_Tite
Keep an ear out for that- it will sing to you quite noticably if it ratchets up too tight. A loud singing/whining sound from the primary that changes pitch with the rpm's.
I've had to reset my chain tensioner and will not be making any drag-race starts anymore unless I feel the desire to do it again. The automatic tensioner is on the side that the chain will get sloppy and loose because it gets pushed into the clutch sprocket, while the top side gets stretched tight from being pulled away from it.
Old Jun 2, 2012 | 09:40 AM
EdwardK's Avatar
EdwardK
Lucky for me the input shaft bearing took out the seal and it started to leak before total failure at 72,000 on my 08 RKC. I rode it to the shop. Everything else internal but the bearing and seal survived. Nothing $900 couldn't fix. I had been using Mobil One gear lube 75-90. They recommended switching to Redline. We'll see how many miles I get that.
Old Jun 2, 2012 | 09:46 AM
soft 02's Avatar
soft 02
Thats why Baker came out with a better tensioner for late model bikes.
http://bakerdrivetrain.com/attitude-chain-adjuster
It goes both ways.
