Suggested engine upgrades at 50K miles
Old Jun 7, 2012 | 08:20 AM
jcp0330's Avatar
jcp0330
Default Suggested engine upgrades at 50K miles
I have a 2009 FLHTCU with a little over 50K miles. Since the bike is paid off and has lots of changes to fit me I really want to keep it a few more years. I'm riding about 15K a year. I'm running a V&H fulepak, Power duals, and Monster Ovals. I just had the rear lifters replaced under extended warranty. I'm starting to think at mileage of 50K maybe I should start doing some preventive maintnenace upgrades to keep the bike running great and to avoid any major problems or large expenses. I have a year left on the extended warranty.
Does anyone have any suggestions?
Thanks.
Old Jun 7, 2012 | 08:29 AM
dbell66253's Avatar
dbell66253
Keep it running for one more year with routine maintenance then get a 120R.
Old Jun 7, 2012 | 08:30 AM
TOMMAY's Avatar
TOMMAY
Replace cam tensioners and while you're in there upgrade to a better cam and go ahead and replace the oil pump.
You might be able to get this done under warranty except for the price of the cam if your tensioners are making destructive noises now.
Old Jun 7, 2012 | 08:54 AM
BugBYter's Avatar
BugBYter
2009 has the upgraded hydraulic tensioners, shouldn't be a problem at 50k.
If you're happy with the performance of the bike, just keep up the regular maintenance and put another 50k on it.
Old Jun 7, 2012 | 09:33 AM
myy2khog's Avatar
myy2khog
X2. With normal maintenance, should be easy to get 100K if you don't overheat it.
Old Jun 7, 2012 | 10:19 AM
PassRusher75's Avatar
PassRusher75
I say run it, consider adding to your extended warranty - prices can vary, deals can be found if you look around. Warranties are a gamble at best, but worth a thought. Sounds like you may have broke even first time around...
Shoot for 100K, then plan your next move.
Old Jun 7, 2012 | 10:24 AM
2011Deluxe's Avatar
2011Deluxe
I like this option the best
Old Jun 7, 2012 | 11:42 AM
jmorganroadglide's Avatar
jmorganroadglide
Big Kahuna HDF Member
At some point in time HD used poor quality bearings. Engine and wheel bearings are areas that I have read may be a problem. As usual, this could be BS.
Rain
Mar 31, 2010 08:12 AM
ArizonaFalconer
Nov 23, 2009 12:38 PM
madmikee
Aug 13, 2009 01:26 PM
nwbobnw
Feb 21, 2008 06:11 PM
edilgdaor
Oct 22, 2007 05:14 PM
